is rcjoycon compatible with RR
  • is rcjoycon compatible with RR
    is rcjoycon compatible with RR? it does works with centrafuse.
    Doesn't it just map keystrokes to the steering wheel controls? If so you can specify what keys do what skin commands in RR. See the following:
    within the RR directory:
    KeyTBL.ini
    Keycode.exe
    within the documentation folder
    skincommands.txt
    Once you specify the keys to use map RCjoycon to those keys.
    Good luck!
    -Deric
    Click for my projects
    2006 F150 with removable Nexus 7
    2006 Mustang with indash CarPC (Retired)
      oh kool.
      has any one tried it on RR yet?
        Yes, I have and it working fine.
          do you have any pics of installatoin? any problem while hibernation and resuming?
            JoyCon is connected to Sony RM-X2S remote so nothing special to show. No problems with hibernation and resuming. Only problem is that my motherboard Intel D945GCLF2 hangs on boot 10sec before starts loading Windows, developer promise to fix it if he find what causing it.
              Ahh that's why my D945GCLF2 suddenly takes longer to POST. I was gonna go investigate what it was, but I'm pretty sure the JoyCon was the last thing I installed.
                Observed the same on my D945GCLF2 too, post takes quite long, and also the time after "resuming" takes quite long. I am running W7.
                Hope the developer fixes it !!
                Honda City
