Voice Tags, the second
  • Voice Tags, the second
    I have the same question like here.
    But i dont understand, why RR say only in some Menu´s a little text. In my Skin it says "external GPS" and "Pictures". No words in "Main" or "Music".
    When i use the SAY-Command, it say first the global word and after that my SAY-Command. Thats not good.
    When i switch in RR.ini the Voice off, then the SAY-Command not works. Thats also not good.
    In many Skins work global Commands, like GPS to load a external_GPS.skin with the settings in the rr.ini. For this it would be not good, when i must change all global Commands to a LOAD-Command, only to use my own SAY-Commands.
    It would be better, when i can change in RRConfig the global SAY-Commands, or no Menu have a SAY-Command and i can completly use my own SAY-Commands in my Skin, like "GPS||SAY;"Navigation".
    i think RRExtended plugin has a text to speech command, not sure, what you can do if it does is, disable voice in rr.ini and try RRextended.. good luck
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
      That was the primary reason that I added that feature, but also can be used lots of other places as well...
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        There are only a few voice prompts defined in RR -- they only play when no music is playing. You can easily override the few prompts in RR with the LOAD command (and replace it with blank), then you can choose to use the say commands with your own voice prompts when desired.
        Ride Runner RR's Myspace
          Say Command only works when you have voice enabled in RRconfig. If not, you can use the command Talk.
            But mine auto ramps down/up the vol of the current source, so that you can hear it too..
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              Okay, thanks to all- i will test RRextended.
