restarting roadrunner
  • restarting roadrunner
    Is there a command or syntax I can use to gracefully restart the roadrunner outside the skin, in a command line? thanks...
    broom-broom-pc
    m-atx:amd2600xp:512mb:40gb:m2-atx:roadrunner:lsxvoid
    You can use Autoit to write a simple script that will close road runner (something like WinClose(xxx) then the next line would just run the roadrunner exe. Have a look at the Autoit forums/tutorial
      In your rr folder you will find a exec.exe. All you need to do to accomplish this is run the exec.exe with a parameter of RELOADRR.
      Example:
      exec.exe RELOADRR
      You can use it basically as a CLI for RR. You can also string cmds together.. exec.exe AUDIO||WAIT;3||LIST ... would load the audio screen, wait 3 secs, then load the audio browser screen.
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        thanks for the quick reply... i tried the exec portion and it works wonderfully... i'm also looking at autoit as you could do so much automation stuff outside of rr as well
        broom-broom-pc
