RR 09-22-2009 Release
  • RR 09-22-2009 Release
    We have reviewed the release and fixed a few issues reported. Available now for all.
    Another month, and another RideRunner...
    Continous Improvement!
    *** Available now from here ****
    Updates soon:
    ** 9/23/2009 - Albumart art bug is fixed... (sorry) **
    ** 9/24/2009 - Silabs internal audio (USBRadio.dll) is fixed... (double sorry) file is attached to post **
    ** 9/24/2009 - Standard list, black bar on 1st item in DL, when DL has music files is fixed... **
    ** 9/28/2009 - fixed issue with caching of tags **
    ** 9/29/2009 - fixed Playlist issues on older winamp (non unicode) versions **
    WARNING: If you use the LOADLIST command for VIDEO playlists AND you use filenames with complex characters (i.e. Chinese, Japanese, Hebrew, Russian, etc), then you may have to re-do your saved playlists OR wait for the next release.
    Some highlights:
    we got blink rates for indicators now
    Improved unicode support!!!
    Improved performance of some features.
    A lot of work went into this months release:
    Thanks to Spidermunz for all his help in helping me understand some of the advanced features of RDS
    of which arnt used in USA so its was/is very hard for me to test them, yet alone
    understand them. He has shared with me his EON code for the SiLabs Driver (usbradio.dll) I have added in
    some of the featues into the silabs radio module and made some other changes to it...
    this is for sure a work in progress...
    currently Spidermunz and I continue (even as i write this) to work on it
    thanks Guino for his CONTINUED improvement of RideRunner
    thanks to Bluezx3, for his commitment to this, and for RRConfig
    edit: thanks to Mitch for his great contributions (software+hardware) to the community
    Notes:
    silabs radio, audio disables itself (audio), when you use "uselineinplugin=true"
    this allows the winamp lineinplugin to work nicely,
    audio is able to be processed by winamp (dsp,eq....)
    thanks
    Mitch
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    9/22/09
    # Fixed CLICKIND for indicators inside buttons
    # Fixed Issue with ONSONGSTART (executing for every screen)
    # Fixed Issue with Daylight Savings on Gamma/Skin GPS based changes
    + Added "Daylight Savings" awareness to the gps gamma feature
    9/21/09
    + added additional field for label definitions
    	/,  x   y   w   h   r   g   b   pt font             Code tooltip format
    	LXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XX,"Arial Narrow:B",CODE,"Time","fmt"
    	examples:
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=kb","LEFT","kb"                              (shows mem in kb, with static text of kb)
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=kb   ||MBM1","LEFT","kb||||cf2"        			 (shows mem in kb, and temp in f, "f" is automaticly appended)
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=kb   ||ALLMEM||=kb","LEFT","kb"              (shows both in kb)
    		L,474,75,250,27,212,208,200,16,"Arial:B","FREEMEM||=   ||ALLMEM","LEFT",""                       (shows both in mb with spaces a static text)
    9/18/09
    # fixed resumemusic=1, now resumes to radios since the wording "music" is a loose term (also activesource is correct when resumemusic > 0)
    # fixed issues with custom labels
    9/11/09
    - Removed Disable Internationalization Setting (obsoleted)
    + Improved OSKTOCMD and NUMOSKTOCMD to accept ++ in place of ||
    + Custom indicator blink rates
    * More skin cleaning/organizing done
    9/10/09
    - "LOCALE" - rr.ini setting obsoleted
    * MPC Video Player Updated to work with unicode filenames (All other players are already unicode compliant)
    + "RDSEON" - Indicator the RDS EON is present (SiLabs)
    + "RDSAFLIST" - Label RDS AF List (pipe seperated "|") (SiLabs)
    + "RDSEONCOUNT" - Label RDS EON Map Size (SiLabs) (ment for use in plugins)
    + "RDSEON1" - Label RDS EON Map x - (Pipe seperated "|") (SiLabs) ("PI|PS|PTY|TA|AF1|AF2...AFn")  (ment for use in plugins)
    + "RDSEON2" - (see RDSEON1)
    + "RDSEON3" - (see RDSEON1)
    + "RDSEON4" - (see RDSEON1)
    + "RDSEON5" - (see RDSEON1)
    9/09/09
    + "uselineinplugin=true/false" RR.ini setting automaticly disables internal audio when TRUE (SiLabs)
    9/08/09
    + "RDS_TA" / "TA" - Skincommand to enable disable traffic alert events "ONRDSTASTART" & "ONRDSTAEND" (SiLabs)
    + "RDS_TA" / "TA" - Indicator, shows state of traffic alert events (SiLabs)
    9/04/09
    + Improved Tag Reading to work better with Unicode File Names
    + Improved Labels to work better with Unicode Text
    + Improved Standard Lists performance
    + Improved Album Art Browse performance
    + Improved iLists and Standard Lists to work with PNG, JPG and other GDI+ file types
    + Improved Audio Players to work with Unicode
    # Fixed LazyTag option bug on Folder Lists
    # Fixed issue Closing MPC on some machines
    9/01/09
    # label click "exec;xxxx" fixed ending " is now allowed
    8/28/09
    + Custom Blinking rate to indicators
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks for your great job.
    We're waiting the release.
      Again sure a good new release
        Do you sleep?
        You guys are amazing. I just finally got 08-01-09 in and now I'll be even further behind. Thanks for all the hard work ALL of you guys put in. RIDE RUNNER is the main reason I put a computer in my truck and ALL of you continue to prove to me I made a SMART decision. I hope all involved will continue to have the time and patience to update and improve RR.
        For those who fought FREEDOM has a flavor the PROTECTED will never know. Support our troops.
          Thanks!
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            a toast to you guys
            Riderunner / Genesis
            Wifiman_NET:Version 1.0.0
              this is nice..
              thanks guys, downloading the new version.
                So, what I need to do now to get audio from radio (Silabs). It was working fine until now! I also try enable line in plugin but that not work either.
                I get quiet hissing when I go radio and it stops when I go music.
                Should I change text in line in plugin box or should default "line://title=Radio,srate=44100,bps=16,nch=2" work? I'm using Winamp 5.552
                Edit:
                I get it to work after few reboots, but there still something wrong:
                If I listen music and restart RR both radio and music start to play at the same time???
                If I listen radio and restart RR then it start to play radio like it should.
                If I listen radio and go to video, radio stays playing behind video???
                  I'm using silabs radio and something wrong with my system also;
                  Radio start to play everytime RR starts?
                  Also something wrong with winamp playlist, if I switch to TV (winamp plugin) and back, getting empty playlist named "rrpl"?
                  Thanks for the release..
                    woops
                    SilAbs fixed
                    see 1st post
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Edit:
                      dartman, that winamp linein example wont work, it need to know what device
                      u need to read how to use the winamp linein plugin...
                      and need to have the right one even installed
                      http://home.hccnet.nl/th.v.d.gronde/...WA2/index.html
                      but the regular audio is fixed
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        I just try new fixed dll and it's working perfect! I don't know what you and spidermunz have done but now stations change faster than ever and feels like rds is faster too.
                        I was trying Winamp linein plugin because regular was not working.
                        Thank you very much.
                          Thanks for the great work guys.. i am having a minor issue though.. When rr loads, i get a popup complaining about vidoe resource not enuf.. set the screen num. below 0.. something like that.. i've never had that popup before...
                          edit,
                          this happens everytime i load a new screen and a little sluggish.
                            Same here. Did any of the GDI stuff get changed this month? Seems slower and I know on my testbed its gotta videocard/display related.
