Song info doesn't display properly
  • Song info doesn't display properly
    No matter what skin I'm using, I cannot get Road Runner to display the song info (Artist/Song) correctly.
    In Carwings it shows the song name under both Album & Song, and when I use DigitalFX4.0 it shows the song name only under the Artist heading.
    I've tried almost everything in the RR config app... turning on ID tags, turning them off...
    I don't know what else to do.
    I've also tried this on 3 different computers with the same results.
    Last computer I tried it on I'm using the latest version of RR with Winamp 5.13 (as recommended by DigitalFX4).
    And insight to this would be great!
    what version are the ID3 tags? try using an ID3 program to convert them to a different version and see if it helps
      Some are V1, others are V2.... Doesn't seem to make a difference.
        could also be how winamp is supplying tags... u can control it in winamp...
        should attach your RR.ini when you need help on a topic like this
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          thanks, but I actually got my answer from this thread:
