"locale" settings keep resetting
  • "locale" settings keep resetting
    so i'm trying to set up RR so that it displays cyrillic characters in music player. Winamp 5.24 is installed with Classic Skin.
    I follow the instructions in other threads and set the RR Config Locale to Russian; then i select Save and Exit or Save and Launch. Either way, when i open RR Config again, the Locale resets to English.
    The XP SP3 is English, Russian is set as default language and all other settings are set per the instructions in other numerous threads.
    so i figure the problem is with RR Config. Can someone help?
    thanks in advance.
    Yes, if you happened to nab the 9/x release before it was removed, then it not something going wrong. As of the 9/x, when rereleased, has done away with that setting as its been made to support unicode.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      i have the latest version - redownloaded it today
      So the version available for download right now is not the one i need?
        No, they took down the latest version to fix some bugs.
        OLD SYSTEM (DEAD)
        Intel D945GCLF2 Dual Core ATOM
        Lilliput 7" 629GL 2008 LED Backlight
        BU-353 USB GPS Receiver / iGuidance / IGO8
        M2-ATX Power Supply
        RideRunner Front End / Various Skins
        Windows XP SP3
          most recent version.
          OK, that explains a few other things, too.
          Thanks.
