what antenna/setup to use w/ ADS instant FM
  • what antenna/setup to use w/ ADS instant FM
    I have the ADS FM and cannot get constant good reception. I tried following someone's recommendation of soldering a cable which allow me to connect to the car radio. This also goes in and out. Is there anyone using this unit successfully in their car?
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
    for sure u need that mod, with the wire, inside it doesnt do very good
    and im sure in a car...
    even with the mod.. antenna issues maybe there
    in your car, what kind of antenna you have, in glass?? its it amplifed? did u power on the the amplifer....
    course ur in USA, HD Radio would do u better, its tuner made for a automotive use... but some of the antenna issues would remain, ie amplified....
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      from my understanding, the ADS unit does not work well with the glass mount antenna of any vehicle so i disconnected the cable from the glass mount. Yesterday i was getting superb reception while in the city. As i was driving back home i began losing reception and when i was home i could not get anything. That is until i move the antenna or play around with it.
      My point is to know if there is an antenna i can get to add to the unit. I like it and it works well "when it works" - i think a good antenna will resolve this issue..
      Atom - 1.8ghz
      2GB Ram
      32GB SSD
      8" TouchScreen
      Finished Project
      Car Hacking
      WorkBlog
      Video
        none that i know of... all antennas are a bit of a hack on those tuners
        u did have the glass antenna powered on right? they are usually amplified
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          not sure what you mean by amplified as the glass antenna is the factory antenna provide with the factory car. I'm not sure how the factory installation is setup?
          I did, however, go to radio shack and purchased an amplified antenna (which i can return for full refund) connected it, plugged the ac adapter into an outlet and depending on where i positiioned the antenna, it would work great but that's unacceptable.
          I have a strong feeling the usb fm radio is getting feedback from the pc, wires, hubs and the likes. What i'm considering doing is getting a long usb extension cable, running it to the back of the car and plugin the fm radio by itself back there. we'll see if this works...
          Atom - 1.8ghz
          2GB Ram
          32GB SSD
          8" TouchScreen
          Finished Project
          Car Hacking
          WorkBlog
          Video
            the pc might be killing fm too
            but 99% of all on glass antennas are amplified
            the factory radio, 1 turns on a amplifier remotely mounted in car
            or 2 contains the amp
            if your not using the factory radio, to use that antenna, you have to turn it on
            basic car audio...
            maybe ask a car audio shop
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              @mitchjs
              i kepted my DIC and factory radio intact. I disconnect the antenna from the factory radio and connect it to my USB FM unit and nothing.
              What i may try is extending the cable to the usb fm as far away from the pc/cables/hubs and running a connection to the antenna.
              Atom - 1.8ghz
              2GB Ram
              32GB SSD
              8" TouchScreen
              Finished Project
              Car Hacking
              WorkBlog
              Video
                are u keeping the factory radio ON??? when ur trying to use the antenna
                it also can send the power up the antenna wire (like vws do, and u need an adaptor)
                you might want to do more research on you car...
                its a high end car, not a toyota!!!
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  Hi, I ordered an ADS InstantFM stick and I have a glass mounted antenna on a VW T4. There is an amplifier that fits with the factory radio. Maybe this kind of adapter will work.
                  http://www.carteq.fr/categories/gran...-pour-voiture/
                  Sorry but it's french
                    thanks, i will look into this on my car forum...
                    in the meantime, i'm going to also try distancing, using another antenna i'm borrowing from a friend, and better soldering connection to the cable.
                    Atom - 1.8ghz
                    2GB Ram
                    32GB SSD
                    8" TouchScreen
                    Finished Project
                    Car Hacking
                    WorkBlog
                    Video
                      FOR sure the on glass is amplified... its just a question where/how to enable the amp
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Hey did you get anywhere using a different antenna and a usb extension ?
                          I too am using the ADS Instant FM. I was just curious if anyone got this to work well with a Hacked Antenna.
                          I am debating on using the car stock antenna as well. Mine is not in the windshield, but on top of the car I belive (2007 Chevy HHR). I am not sure how to make the two connect though as they are clearly differnt sizes.
                          Thanks,
                          Rog
                            I believe many people have soldered a cable for a bigger antenna on the Silabs/ADS modules -- I have done it and it helps a lot.
                            Ride Runner RR's Myspace
