Road Runner slide show
  • Road Runner slide show
    Hi I m using Road Runner I wont to display the picture with a slide show
    Envy idea ?
    You need to give more information
    Road Runner version
    OS version
    Which Skin are you using
    Do a search for slide show
    Have a read of the FAQ's
    Read the example of how to report a bug in the RoadRunner bug reporting forum
    And before mitch says it, make sure you are running the lastest RideRunner if you want help from the developers.
      ah now enforcer that was a little harsh on a newbie ...
      I think he was asking if there is anyway to have a slideshow of photo's using native RR commands ...
      elli_h:
      if I'm correct I don't think there is .. perhaps someone may be writing an AI script of a PI to do this but at the moment the only way I've found is to use an external imageviewer / program.
      The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
        elli_h:
        RR can do a pic slideshow using a combination of standard RR skin code, but just not "natively" (i.e. BXX,...,"SLIDESHOW","")
        No need for an AI script or PI to do that.
        elli,
        What skin are you using?
        Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
          RR has a slide show facility.
          You use the picviewer screen with a TMR (I use TMR,3 in iDrive),
          in exectbl.ini
          "TIMER","BYVAR;SLIDESHOW;<<NEXTPIC",PICVIEWER. SKIN
          and a button in my picviewer.skin to turn it on and off
          B,000,050,200,050,"BYVAR;SLIDESHOW;SETVAR;SLIDESHO W;1<<SETVAR;SLIDESHOW;0",""
          *edit, dammit Sal you got in there before me.
            Well I stand corrected gentlemen, you learn something new everyday ..
            So now that's another external program I can drop from my skin ... yipee..
              Hi thenks fore the reolay
              I am using the last Ver of RR with Carwings_Dynamic_Lite skin
                in exectbl.ini
                enforcer , i try to use that slidershow , but dont work for me
                but i see into skin tool how change , but the picture dont change
                into skin toool say this
                NEXTPIC
                NEXTPIC
                  I think that RRandomBackground do that for you !!!
                    NEXTPIC
                    NEXTPIC
                    Well that shows that the code I have giving you is working perfectly.
                    NEXTPIC is a RideRunner code
                    "NEXTPIC" - Skips to next picture in the picture viewer
                    This must be in the picviewer.skin or bigpic.skin (I think that's true)
                    Make sure your picspath has a path with images in it.
                    Just checked my iDrive skin and this is the code I have used and it still works perfectly
                      just a tip:
                      open the carwings skinfiles and look what you miss in yours.
                      you always send snippet parts of your skin file. it's difficult to understand, when you don't show the skin file.
                      RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
                      RR-Plugin: IBusCommunicatoRR new Updates
                        i use this way , and working fine
                        PICTUREVIEW.SKIN
                        RideRunner Skin
                        RRScreen picviewer
                        /INC,Topbar1.txt
                        IMG,24,78,508,403,"IMAGENS\Wood9.png",ALL
                        IMG,708,13,40,35,"Icons\speaker icon.png",ALL
                        J01,44,89,468,380
                        L,144,537,101,23,255,255,255,13,"HandelGotDLig","= Slideshow","CENTER",
                        L,300,26,177,31,255,255,255,20,"HandelGotDLig:B"," =Pictures","CENTER",,"ds=2,2,0,0,0"
                        L,616,23,80,18,255,255,255,11,"HandelGotDLig:B","= CPU: ||CPU","LEFT",
                        L55,38,89,480,380,,,,,,"EXEC;LOAD;picture.skin","" ,
                        B,148,521,94,58,"BYVAR;SLIDESHOW;SETVAR;SLIDESHOW; 1<<SETVAR;SLIDESHOW;0||LOAD;PICVIEWER_FULL.skin",
                        B,42,521,94,58,"LOAD;PICTURE.SKIN",
                        B22,0,2,86,56,"EXIT",
                        B,554,522,98,58,"UP",
                        B,662,522,89,59,"DOWN",
                        B22,253,522,90,58,"BROWSE",""
                        B23,452,521,92,61,"BACK",""
                        B,713,13,35,35,"MENU;VOLUME_MENU.SKIN",
                        B,351,495,94,95,"BROWSE","SELECT"
                        IL,DL,transparent.bmp,sel1.bmp,end.bmp,1,50,80
                        S04,557,98,193,365,255,255,255,57,57,57,255,255,25 5,255,255,255,200,200,200,0,0,0,TRUE,15,"HandelGot DLig:B"
                        END
                        and PICTUREVIEW_FULL.SKIN
                        RideRunner Skin
                        RRScreen "PICVIEWER_FULL"
                        PICVIEWER_SLIDER.png,PICVIEWER_SLIDER.png,PICVIEWE R_SLIDER.png,PICVIEWER_SLIDER.png
                        TMR,4,"BYVAR;SLIDESHOW;<<NEXTPIC"
                        I01,0,0,800,600,"PICTURE:A",,,
                        RG,0,0,200,600,"PREVPIC"
                        B,200,0,400,600,"BYVAR;SLIDESHOW;SETVAR;SLIDESHOW; 1<<SETVAR;SLIDESHOW;0||EXIT",
                        RG,600,0,200,600,"NEXTPIC"
                        /, Hidden List
                        S,0,0,0,0,,,,,,,,,,,,,,,,,,
                        END
                        my problem is when i click slidershow button in skintool put SLIDESHOW;1 so tunr on slidershow , but i dont turn off , for when i open full screen again working fine , so now , when click on screen full turn off , and then if like it open again the screen full , begging again turn on
                          yes the button which loads the fullscreen, sets the var slideshow to 1
                          check the var SLIDESHOW in skintool.
                          when you turned:
                          -on, there must be a 1
                          -off, there must be a 0
                            yes , i see that , that is one of my error
                              why not fix it?
                              does it mean you want an own button to switch ON/OFF the slideshow?
                              and one button only to switch to fullscreen?
