RR/Winamp Shuffle
  • RR/Winamp Shuffle
    I have always added my entire collection to the playlist and let it play on shuffle. Once and a while I would get to a song/artist of an album I liked. I would just take it off shuffle and it would resume normal play mode. I would advance to the next track in the album and so on. Now, when I take it off shuffle in the middle of the playlist it seems to still be shuffled and skip around. It will advance to a different album of the same artist or just continue down alphabetically but not in order. It's like when I load the playlist of "ALL/Entire" or just using RR MEdia DB to play select "Entire" it loads the Entire Collection pre shuffled. What changed? What can I do to get it to play the entire collection in proper succession? Thanks.
    I'm comprehension. Have we met?
    Seriously, I can't understand any of that but maybe try loading Winamp on its own and get your playlist set the way you want.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
      Well, sorry it didn't meet your IQ.
      Load an album songs 1-9.. Put it on shuffle. lets say you are now on track 5. Take shuffle off and when you press to advance to the next track it should be track 6. In my case, when shuffle is turned off for (ie) track 1-9, it will go from track 5 to track whatever it wants ,7,2,4...I did not always do this and I do not recall changing any settings regarding the issue. It just happens to be an on the fly playlist. I Play my entire collection on random, I want to be able to turn random off when I hit an album I like, and have stay there.
        Things to try:
        1. Is it randomizing the playlist and playing the randomized list in order? Or is it actually jumping to the second song in the playlist while looking at it?
        2. Some skins have the same button for loop and shuffle. With Carwings Dynamic you have to hit this button twice to get shuffle turned off because it cycles through shuffle, loop, shuffle and loop, nothing. Or maybe it's random instead of loop, I forget what the other one is, I don't use it.
        3. Load the playlist in Winamp and see if it behaves the same way.
        Ampie Case
        256 MB DDR2 PC5400
        M2-ATX-HV
        2005 Honda Civic
          Things to try:
          Well it was loading the first several songs correctly to the playlist. I have NO odea what I might have done but it seems to be working correctly again after 3 months...Thanks for the good suggestions
            You can also disable the hideplayer option and just "view" the songs in winamp's playlist to see what's going on. You may even just look at winamp (outside RR) after you loaded all your songs to see if they're in the desired order. I suggest you try this first on a basic skin like carwings/bmv2 as some skins/plugins can modify the behavior of standard functions.
            Ride Runner RR's Myspace
              You're frustrating the hell out of me, this post is just as vague as your original post and makes no sense. Is it fixed? Does it work now? How did you fix it? Other members may have the same issue and will find this thread on a search. It would be helpful for them to have a solution. Thanks.
              Ampie Case
              256 MB DDR2 PC5400
              M2-ATX-HV
              2005 Honda Civic
                RRMedia will only shuffle the list if and only if you have the list mode set to random other wise it creates the list in the same order in which is was indexed in (by folders)
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
                  It is "fixed"
                  Here is what I believe my problem was. Aside from having shuffle on in RR, in RR Media I had "Sort By Song Number" on as well. I figured this would arrange songs in albums by Number as most of us would like. But what I think was happening was that it was loading the "All/Entire" into the playlist by "Song Number". So when i got to an Artist with multiple albums containing several songs by that artist with a track # of 8, it would skip to # 8 of each album, and then onto 9, etc.. there for seemingly "still" in shuffle. I changed "play mode" to "by name" and it is back to normal.
                    Good thinking.
                    Ampie Case
                    256 MB DDR2 PC5400
                    M2-ATX-HV
                    2005 Honda Civic
                      Just made a small test in Winamp v5.51. Shuffle order changes everytime the shuffle function is toggled on. Short test, to describe Winamp shuffle.
                      1. Shuffle on, and then next, next...
                      2. This gives the following order of tracks 231, 262, 120, 184, 51, 299
                      3. Then clicking previous button until back on track number 231
                      4. Just to verify shuffle order hasnīt changed, next gives track 262
                      5. Prev to track 9
                      6. Shuffle off, shuffle on, next, next....
                      7. This gives the following order of tracks 259, 210, 7, 186... Completly different from earlier next clicking.
                      Conclusion: Winamp changes the shuffle order when enabling shuffle functiom
                      -> Is it possible to make the next button in a skin to do the following:
                      If shuffle is enabled, disable it and enable it again and then next track?
                      // Tom
                      Gallery of my cars (current and old ones)
                      Nissan 200SX project @ mp3car
                      My old car, VW Passat Variant V5 @ mp3car
                      My modified Kuo skin, named Kuo Blue
                      Speedtest result
                        This is the correct behavior programmed.
                        It is possible to make a command that plays the next song regardless of the shuffle status. On screens with a playlist, this is as simple as changing the command from "NEXT" to "DOWN||PLAY" -- however keep in mind that this is not going to fast forward when you press-and-hold, so you may be better off making a separate button for that, or just click on the song in the playlist and hit play or Double-click it (or even set it to play on single click then just do 1 click on the song).
