RR 10-05-2009 Refresh Release (Available Now)
  • RR 10-05-2009 Refresh Release (Available Now)
    *** Available now from here ****
    A bunch of little things.. we wanted to get this out asap...
    Foobar users, please check the foobar thread (http://www.mp3car.com/vbulletin/rr-r...er-plugin.html)
    WOW!
    First I want to thank everyone who reported and helped get us though all the changes in the last month's build...
    We did alot of clean up in this build. Nailed the bugs introduced when going to full unicode support. One thing to note, Winamp Versions < 5.30 does not support unicode. and Nailed some bugs we introduced during our late night programming...
    Some KEY fixes:
    Albumart Indicator
    Foobar Fixes
    tagcache fix
    Albumart
    Horm fix(actually a resume.ini issue from 8/1)
    Improved icon support on iLists work with PNG/GIF transparency (BLACK also works)
    Fixed Silabs USBRadio.dll not using correct audio capture device
    Standard list, when DL contains music type files, black bar appears on inital selection
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    10/5/09
    # Path bug for plugin data path
    # Foobar2000 player, a few different issues
    # tagcache.ini not saving on exit
    + Added ONRBUTTON, ONMBUTTON events (Right/Middle Mouse Button Clicks)
    # SkinEditor bugs fixed, see skineditor history.txt
    * SkinTool updated v2.0, see skintool history.txt
    * RRconfig, Added wintvpath, closeplayeronexit settings
    9/30/09
    + SKIN DEFINITION "IND" Indicator image modifier property, code improvement (see "new skin commands.txt")
     	IND,NAME OF INDICATOR,PATH TO OFF IMAGE,PATH TO ON IMAGE
     	Example: IND,SHUFFLE,Indicators\Shuffle_off.png,Indicators\Shuffle_on.png
    * Cleaned up "albumart" indicator code
    9/29/09
    # Issues with older winamp versions that dont support unicode playlists
    # Tagache issue on restart
    9/27/09
    # RRConfig, Foobar200 (Manual) setting
    # RRSkinEditor, couple of small fixes (see skin editor history for details)
    9/24/09
    * Improved icon support on iLists work with PNG/GIF transparency (BLACK also works)
    # Standard list, when DL contains music type files, black bar appears on inital selection
    # Fixed Silabs USBRadio.dll not using correct audio capture device
    9/23/09
    # fixed Albumart indicator (aka J skin definition)
    # fixed resume.ini processing at resume from HORM
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Guino,
    Just so I clearly understand. I have a Silabs radio and travel often to unknown cities. Please explain to me in detail, how to load local stations into the RR Radio screen. Yes, I am asking to be spoonfed!!!!
      You can use the "LOCAL" command to switch the station list from normal to local.
      Also the command "SEARCHPRESETS" search all frequencies and save the station in the local station list.
        GizmoQ, johnnyS has it right
        the command "SEARCHPRESETS" will automaticly put you into LOCAL list too
        "LOADLIST;mycoollist.ini" will also load a station list into the LOCAL LIST
        now, do u need me to explain how to drive to a different city? or we good
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          I guess he wants something like this:
          On your home city:
          -Leave LOCAL mode OFF
          -Add your home presets carefully (by hand to be sure)
          When you leave town:
          -Turn Local mode ON
          -Use SEARCHPRESETS or add the local stations by hand (however you like)
          When you go home again turn LOCAL mode off (your home stations should come back).
          That's basically it.
          Ride Runner RR's Myspace
            aww yea birthday release thread
            Live mp3Car Facebook Chat
              yayeah!
              Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                On your home city:
                -Turn Local mode ON
                Thanks, that's a start on what I was looking for. A single button with the command "SEARCHPRESETS" will automatically change the radio screen to local mode and search for and load all local radio stations as well as save them in a file "localradio.ini". I can then create an RRCode script to rename it and load it later using the LOADLIST command, but I have to switch to localmode manually first. Is that right?
                For clarification, I have some more questions. Above what signal strength does this search occur? and can that level be adjusted? In what directory is the "localradio.ini" saved? If I don't switch to localmode first, will the LOADLIST of a saved "localradio.ini" over write the "radio.ini"? If I shut down the computer while listening to the radio in local mode, when I turn it back on will RR's radio still be in localmode still on the channel I was previously listening to? As I understand the above, the RADIO_MENU_FUNCTION.SKIN is no longer necessary - Please verify/confirm for me.
                Thanks for the quick reply.
                  I'm sure this has been mentioned before, but are there any plans for RR to support MediaMonkey in the future?
                  My Worklog
                  2006 Tungsten Grey GT | Dark Charcoal Leather | 18" Fanblades | Spoiler Delete
                  C&L Intake | Bullitt Mufflers | MGW Short-throw Shifter | MGW Interior Pieces
                    Mitch's dept...
                    Going by code... I belive that it should be in the RR's Root (most likely).
                    Next in line: RRMedia v2.0
                    DFX 5.1.1 Skin
                    Appstore Link
                    My RideRunner Plugins
                    RRMedia
                    RRExtended
                    DFXVoice
                      This should have been posted in the new RR Project section at top. Under Feature request...
                      Thanks.
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
                        Perhaps this has been discussed before, but I didn't see it and think it would be good practice...
                        Would it be possible for the downloads to have the date / version number included in the file name?
                        Mostly Useless Info - Free Image Host
                          i'm working to end the develope of silabs module
                          i think can be make it in 4-5 days (i must add some detail to some function)
                          it is a "porting" and "merging" of my old plugin and base rds/old-silabs module
                          when i save my user-preset (0-9) i name the preset grabbing the rds name
                          if all whants i can name all the station using the rds radio name (if it has), is simple
                          all purpose (if are ok for guino and mitchs) are welcome
                          [QUOTE]Above what signal strength does this search occur? and can that level be adjusted?/QUOTE]
                          in my old plugin i can adjust the level strength under the radio must search an alternate frequencies, user can set it inside the silabs.ini config file (r from a form inside rr (in my old plugin)
                          2 example:
                          preset rds name (i use a popup )
                          http://www.mp3car.com/vbulletin/rr-p...ml#post1232910
                          and the form loaded inside rr by my old plugin
                          Click image for larger version
                          next have less options to be saved (all audio var doesn't be used)
                            GizmoQ, yep... do searchpresets
                            that will switch to local, search for presets, and they save in radiolocal.ini
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              Think I'm the first one to download this month. Thanks for the constant updates and improvements.
                              CAR: 2007 G35 Sport Coupe 5AT
                              HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
