I only got MUSIC section working in RR
  • I only got MUSIC section working in RR
    First of all, I did research in the forum but just still could find my answer.
    I installed latest version of RR and ffdshow. Please see the screen shots I attached for my video setting. The problem was there was no response when I pressed VIDEO, PICTURES, BROWSER in RR, but MUSIC does and only one does.
    Please, anyone can help me with these.
    Thanx heaps,
    Please try selecting Media Player Classic for Video Player Plugin, then BE SURE TO SET the Media Player Classic Path setting (currently blank). Also set the Path to the Web Browser where it says "To set path, Click -->"
    Try the above then enable Debug mode and post a zip with your RR.INI and debug.txt after trying to use whatever still doesn't work.
    Ride Runner RR's Myspace
      Still doesn't work.
      I've attached both rr.in and debug.txt for your troubleshooting.
        when u started RR, did it ask your permission to elevate?
        your SKIN is a mess... its not actaully doing any of the commands you think it is
        if RR did NOT ask you to evelate (assuming u got UAC on)
        please let me know
        * this really should be running in PROFILE MODE, maybe its time
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          No,my UAC was off, and still.
          I installed RR in my another pc which was xp os,however,I got exactly same problem.
            is it bcoz my SKIN?but im using default one
              very wierd...
              it just should work, u should be able to go into say, video...
              but if u look at the log its not running the command video
              did u touch any of the carwings default files ? exectbl.ini, skin.ini?
              2009/10/11 11:22:39: Executing: SkinButton5
              2009/10/11 11:22:39: Command not executed: SkinButton5
              this is controlled by exectbl.ini
              for sure when u do figure it out, it will be a duh
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                this is wat im trying to say,pretty weird,
                didn't touch any files as well as RRConfig just point video and music path.
                  I just download and installed SKIN "elite lite 1.6.6 .exe", surpised, it is working with all the buttons in this SKIN,
                  however still not working in defaul SKIN
                  don't know howcome
                  still wanna figure it out
                    i dont know... its like the exectbl.ini file isnt working...
                    make sure exectble.ini is in the carwings skin dir, and is not corrupt
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
