RJS ALPS sirius resume issue
  • RJS ALPS sirius resume issue
    I have the USB ALPS1 Sirius setup. When it resumes there's no sound, in addition, at the top of the screen where the channel number and program description are displayed it will display the same channel number as before hibernation, but the description for channel one is displayed. The signal strength bar is stuck at whatever it was when it hibernated, I can scroll the channel list but I can't change the channel. I have to exit and restart RR to get it all to work properly again. Any ideas?
    Thanks!
    Chris
    Chris Krug
    owner, turbine minivan
    http://www.youtube.com/krugtech
    is it wired right???!!
    prob not
    it has to be on when the PC is ON
    which is usually NOT to the accessory position in the KEY
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      It gets it's power from the same relay that turns the PC on, they both get their power turned on and off at the same time. The relay is connected to the RUN side of the ignition switch and has constant power when the key is in any position except OFF. There's a timer on the relay that gives the PC enough time to shut itself down so the ALPS1 gets power as soon as the PC gets power and it has power for a little while after the PC is done hibernating. Should I just wire the ALPS1 to be always on?
      Chris Krug
        it has to be on when the pc is ON
        so... if its on that timer, its ok...
        but make sure... if it shuts off duing the hibernation process, most likely it will cause communication to fail...
        also make sure RR is HibernationAware
        i would turn on sirius debugging, and post me a debug.txt file
        from a session of a complete hibernation cycle
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          How do I turn on sirius debugging and where would I find the resulting txt file? I searched and didn't have much luck.
          Chris Krug
            use RRCONFIG... or manually edit rr.ini
            there is debugging options on page 4
            turn it on, fresh, and sirius
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              There's a debug option in RRConfig, just check it+save, run RR do whatever and check the folder for the log files.
              Ride Runner RR's Myspace
                I did a clean boot, started RR, opened sirius and then hibernated and resumed
                here's the debug with an older ver of RR-
                10/15/2009 1:49:54 PM: Start -- Version: 1/24/2009
                10/15/2009 1:49:55 PM: Master Vol: Volume Control/4
                10/15/2009 1:49:55 PM: GetLineControl Failed: 401
                10/15/2009 1:49:55 PM: No Treble Support
                10/15/2009 1:49:55 PM: No Bass Support
                10/15/2009 1:49:55 PM: No Master ON/OFF
                10/15/2009 1:49:55 PM: Source: Wave=&H1008/1
                10/15/2009 1:49:55 PM: Source: SW Synth=&H1004/2
                10/15/2009 1:49:55 PM: Source: Microphone=&H1003/3
                10/15/2009 1:49:55 PM: Source: CD Player=&H1005/4
                10/15/2009 1:49:55 PM: Source: Aux=&H100A/5
                10/15/2009 1:49:55 PM: Source: Line In=&H1002/6
                10/15/2009 1:49:55 PM: Shell: "C:\Program Files\RideRunner\gamma\gapa.exe"
                10/15/2009 1:49:55 PM: Sim.WMSGs: 1
                10/15/2009 1:49:55 PM: Sim.WMSGs: 2
                10/15/2009 1:49:56 PM: Enter Exec: False, menu.skin, , False
                10/15/2009 1:49:56 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
                10/15/2009 1:49:56 PM: Executing: ONSKINSTART
                10/15/2009 1:49:56 PM: Leave Exec: False, menu.skin, ONSKINSTART, False
                10/15/2009 1:49:56 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
                10/15/2009 1:49:56 PM: Executing: ONSONGSTART
                10/15/2009 1:49:56 PM: Leave Exec: False, menu.skin, ONSONGSTART, False
                10/15/2009 1:49:58 PM: Enter Exec: False, menu.skin, "sirius", False
                10/15/2009 1:49:58 PM: Que Exec: True, menu.skin, "sirius", False
                10/15/2009 1:49:58 PM: Executing: sirius
                10/15/2009 1:49:58 PM: Leave Exec: False, menu.skin, load;sirius.skin;SIRIUS, False
                10/15/2009 1:49:59 PM: Enter Exec: False, sirius.skin, , False
                10/15/2009 1:49:59 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
                10/15/2009 1:49:59 PM: Executing: ONSONGSTART
                10/15/2009 1:49:59 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
                10/15/2009 1:50:09 PM: Enter Exec: False, sirius.skin, , False
                10/15/2009 1:50:09 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
                10/15/2009 1:50:09 PM: Executing: ONSONGSTART
                10/15/2009 1:50:09 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
                10/15/2009 1:53:17 PM: Enter Exec: False, sirius.skin, , False
                10/15/2009 1:53:17 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
                10/15/2009 1:53:17 PM: Executing: ONSONGSTART
                10/15/2009 1:53:17 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
                10/15/2009 1:55:16 PM: Enter Exec: False, sirius.skin, "EXIT", False
                10/15/2009 1:55:16 PM: Que Exec: True, sirius.skin, "EXIT", False
                10/15/2009 1:55:16 PM: Executing: EXIT
                10/15/2009 1:55:16 PM: Leave Exec: False, sirius.skin, load;menu.skin, False
                10/15/2009 1:55:17 PM: Enter Exec: False, menu.skin, "EXIT", False
                10/15/2009 1:55:17 PM: Que Exec: True, menu.skin, "EXIT", False
                10/15/2009 1:55:17 PM: Executing: EXIT
                10/15/2009 1:55:18 PM: Leave Exec: False, menu.skin, menu;exit_menu.skin, False
                10/15/2009 1:55:18 PM: Enter Exec: False, exit_menu.skin, "QUIT", False
                10/15/2009 1:55:18 PM: Que Exec: True, exit_menu.skin, "QUIT", False
                10/15/2009 1:55:18 PM: Executing: QUIT
                10/15/2009 1:55:19 PM: Shutdown
                Here's the new RR ver-
                10/15/2009 2:04:42 PM: Start -- Version: 10/5/2009
                10/15/2009 2:04:42 PM: OS Type: Windows XP
                10/15/2009 2:04:42 PM: FileManager: FileMode = Legacy
                10/15/2009 2:04:42 PM: FileManager: mypath = C:\Program Files\RideRunner\
                10/15/2009 2:04:42 PM: FileManager: ProfilePath = C:\Documents and Settings\Chris Krug\My Documents\RideRunner\
                10/15/2009 2:04:42 PM: SR---> Set object successful
                10/15/2009 2:04:42 PM: SR---> SRLoadIn: SRcache.ini, SRLastChannel=132
                10/15/2009 2:04:42 PM: SR---> SRLoadIn: SRcache.ini, Cache Loaded, Number of SRStations=128
                10/15/2009 2:04:42 PM: SR---> SRLoadIn: Completed
                10/15/2009 2:04:42 PM: SR---> SRPowerON: Port Open Attempt
                10/15/2009 2:04:42 PM: Master Vol: Volume Control/4
                10/15/2009 2:04:42 PM: GetLineControl Failed: 401
                10/15/2009 2:04:42 PM: No Treble Support
                10/15/2009 2:04:42 PM: No Bass Support
                10/15/2009 2:04:42 PM: No Master ON/OFF
                10/15/2009 2:04:42 PM: Source: Wave=&H1008/1
                10/15/2009 2:04:42 PM: Source: SW Synth=&H1004/2
                10/15/2009 2:04:42 PM: Source: Microphone=&H1003/3
                10/15/2009 2:04:42 PM: Source: CD Player=&H1005/4
                10/15/2009 2:04:42 PM: Source: Aux=&H100A/5
                10/15/2009 2:04:42 PM: Source: Line In=&H1002/6
                10/15/2009 2:04:42 PM: PLAYER: Winamp Version: 2.05
                10/15/2009 2:04:42 PM: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
                10/15/2009 2:04:42 PM: No Phidgets interface detected.
                10/15/2009 2:04:42 PM: Plugin Manager: loading Global Plugins...
                10/15/2009 2:04:42 PM: Plugin Manager: loading Global Plugins Completed.
                10/15/2009 2:04:42 PM: LoadSkin: C:\Program Files\RideRunner\Skins\BMV2\
                10/15/2009 2:04:42 PM: Plugin Manager: loading SkinDir Plugins...
                10/15/2009 2:04:42 PM: Plugin Manager: loading SkinDir Plugins Completed.
                10/15/2009 2:04:42 PM: CheckResume: ResumeMusic=1 WasRadio=0
                10/15/2009 2:04:42 PM: CheckResume: Resuming to music player: PLPosition=0 TrackPosition=5670
                10/15/2009 2:04:43 PM: SR---> FindRadioProgress:BEGIN:
                10/15/2009 2:04:43 PM: SR---> FindRadioProgress:START: COM9:
                10/15/2009 2:04:43 PM: SR---> FindRadioProgress:RESET: COM9:
                10/15/2009 2:04:43 PM: Enter Exec: False, menu.skin, , False
                10/15/2009 2:04:43 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
                10/15/2009 2:04:43 PM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
                10/15/2009 2:04:43 PM: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
                10/15/2009 2:04:43 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
                10/15/2009 2:04:43 PM: Leave Exec: False, menu.skin, ONSONGSTART, False
                10/15/2009 2:04:43 PM: SR---> FindRadioProgress:FOUND: COM9:
                10/15/2009 2:04:43 PM: SR---> FindRadioProgress:COMPLETE:
                10/15/2009 2:04:43 PM: SR---> oSR_SiriusEventPortOpened: .PowerOn
                10/15/2009 2:04:45 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||sirius", False
                10/15/2009 2:04:45 PM: Que Exec: True, menu.skin, "ONBTNPRESS||sirius", False
                10/15/2009 2:04:45 PM: Que Exec: True, menu.skin, "sirius", False
                10/15/2009 2:04:45 PM: Executing: sirius
                10/15/2009 2:04:45 PM: SR---> SRActive:
                10/15/2009 2:04:45 PM: SR---> SRActive: Not powered on (yet)...
                10/15/2009 2:04:45 PM: Que Exec: True, sirius.skin, "ONSCREENCHANGE", False
                10/15/2009 2:04:45 PM: Que Exec: True, sirius.skin, "ONSOURCECHANGE", False
                10/15/2009 2:04:45 PM: Leave Exec: False, sirius.skin, ONSOURCECHANGE, False
                10/15/2009 2:04:45 PM: SR---> oSR_SiriusEventRadioReady:
                10/15/2009 2:04:45 PM: SR---> SRPoweredON: SRON=True,SRTuneTo=132
                10/15/2009 2:04:45 PM: SR---> SRActive: Tune to...132
                10/15/2009 2:04:46 PM: Enter Exec: False, sirius.skin, , False
                10/15/2009 2:04:46 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
                10/15/2009 2:04:46 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
                10/15/2009 2:04:46 PM: SR---> oSR_SiriusEventVBChannelChanged:
                10/15/2009 2:04:52 PM: SR---> oSR_SiriusEventAntennaStatus
                10/15/2009 2:04:52 PM: SR---> Radio channel active = 132
                10/15/2009 2:04:58 PM: Enter Exec: False, sirius.skin, , False
                10/15/2009 2:04:58 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
                10/15/2009 2:04:58 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
                10/15/2009 2:05:01 PM: SR---> Radio FULL Channel Fetch done
                10/15/2009 2:09:06 PM: WM_POWERBROADCAST: wParam=6
                10/15/2009 2:09:06 PM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
                10/15/2009 2:09:07 PM: WM_POWERBROADCAST: wParam=6
                10/15/2009 2:09:07 PM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
                10/15/2009 2:09:21 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||EXIT", False
                10/15/2009 2:09:21 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||EXIT", False
                10/15/2009 2:09:21 PM: Que Exec: True, sirius.skin, "EXIT", False
                10/15/2009 2:09:21 PM: Executing: EXIT
                10/15/2009 2:09:21 PM: Enter Exec: True, menu.skin, , False
                10/15/2009 2:09:21 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
                10/15/2009 2:09:21 PM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
                10/15/2009 2:09:23 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
                10/15/2009 2:09:23 PM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
                10/15/2009 2:09:23 PM: Que Exec: True, menu.skin, "AUDIO", False
                10/15/2009 2:09:23 PM: Executing: AUDIO
                10/15/2009 2:09:24 PM: SR---> SRInActive:
                10/15/2009 2:09:24 PM: SR---> SRMute: .MuteOn
                10/15/2009 2:09:24 PM: SR---> SRInActive: SRON=False
                10/15/2009 2:09:24 PM: Enter Exec: True, audio_player.skin, , False
                10/15/2009 2:09:24 PM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
                10/15/2009 2:09:24 PM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
                10/15/2009 2:09:24 PM: Que Exec: True, audio_player.skin, "ONSOURCECHANGE", False
                10/15/2009 2:09:24 PM: Leave Exec: False, audio_player.skin, ONSOURCECHANGE, False
                10/15/2009 2:09:24 PM: Enter Exec: False, audio_player.skin, , False
                10/15/2009 2:09:24 PM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
                10/15/2009 2:09:29 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
                10/15/2009 2:09:29 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
                10/15/2009 2:09:29 PM: Que Exec: True, audio_player.skin, "PLAY", False
                10/15/2009 2:09:29 PM: Executing: PLAY
                10/15/2009 2:09:29 PM: Leave Exec: False, audio_player.skin, play, False
                10/15/2009 2:09:31 PM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
                10/15/2009 2:09:31 PM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
                10/15/2009 2:09:31 PM: Que Exec: True, audio_player.skin, "EXIT", False
                10/15/2009 2:09:31 PM: Executing: EXIT
                10/15/2009 2:09:31 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
                10/15/2009 2:09:31 PM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
                10/15/2009 2:09:32 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||sirius", False
                10/15/2009 2:09:32 PM: Que Exec: True, menu.skin, "ONBTNPRESS||sirius", False
                10/15/2009 2:09:32 PM: Que Exec: True, menu.skin, "sirius", False
                10/15/2009 2:09:32 PM: Executing: sirius
                10/15/2009 2:09:32 PM: SR---> SRActive:
                10/15/2009 2:09:32 PM: SR---> SRMute: .MuteOff
                10/15/2009 2:09:32 PM: Que Exec: True, sirius.skin, "ONSCREENCHANGE", False
                10/15/2009 2:09:32 PM: Que Exec: True, sirius.skin, "ONSOURCECHANGE", False
                10/15/2009 2:09:32 PM: Leave Exec: False, sirius.skin, ONSOURCECHANGE, False
                10/15/2009 2:09:33 PM: Enter Exec: False, sirius.skin, , False
                10/15/2009 2:09:33 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
                10/15/2009 2:09:33 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
                10/15/2009 2:09:36 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||VOL+", False
                10/15/2009 2:09:36 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||VOL+", False
                10/15/2009 2:09:36 PM: Que Exec: True, sirius.skin, "VOL+", False
                10/15/2009 2:09:36 PM: Executing: VOL+
                10/15/2009 2:09:36 PM: Leave Exec: False, sirius.skin, VOL+, False
                10/15/2009 2:09:37 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||VOL+", False
                10/15/2009 2:09:37 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||VOL+", False
                10/15/2009 2:09:37 PM: Que Exec: True, sirius.skin, "VOL+", False
                10/15/2009 2:09:37 PM: Executing: VOL+
                10/15/2009 2:09:37 PM: Leave Exec: False, sirius.skin, VOL+, False
                10/15/2009 2:09:50 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||PGUP", False
                10/15/2009 2:09:50 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||PGUP", False
                10/15/2009 2:09:50 PM: Que Exec: True, sirius.skin, "PGUP", False
                10/15/2009 2:09:50 PM: Executing: PGUP
                10/15/2009 2:09:50 PM: Leave Exec: False, sirius.skin, PGUP, False
                10/15/2009 2:09:53 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||PLAY", False
                10/15/2009 2:09:53 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||PLAY", False
                10/15/2009 2:09:53 PM: Que Exec: True, sirius.skin, "PLAY", False
                10/15/2009 2:09:53 PM: Executing: PLAY
                10/15/2009 2:09:53 PM: Leave Exec: False, sirius.skin, play, False
                10/15/2009 2:10:00 PM: Enter Exec: False, sirius.skin, "ONBTNPRESS||EXIT", False
                10/15/2009 2:10:00 PM: Que Exec: True, sirius.skin, "ONBTNPRESS||EXIT", False
                10/15/2009 2:10:00 PM: Que Exec: True, sirius.skin, "EXIT", False
                10/15/2009 2:10:00 PM: Executing: EXIT
                10/15/2009 2:10:00 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
                10/15/2009 2:10:00 PM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
                10/15/2009 2:10:02 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||MINIMIZE", False
                10/15/2009 2:10:02 PM: Que Exec: True, menu.skin, "ONBTNPRESS||MINIMIZE", False
                10/15/2009 2:10:02 PM: Que Exec: True, menu.skin, "MINIMIZE", False
                10/15/2009 2:10:02 PM: Executing: MINIMIZE
                10/15/2009 2:10:02 PM: Leave Exec: False, menu.skin, MINIMIZE, False
                Chris Krug
                  just attach the files next time
                  there is NOTHING of use in what u posted...
                  there is no hibernation or resume...
                  just a startup
                  and from that its working fine
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Here's another try. i started up RR, started sirus and it played. At appx 8:06 I hibernated and as soon as it shut down I restarted it and it resumed. When it resumed it was still on the sirius screen and the time was 8:08 but srius was locked up as described above again. You can see in the log that there's a gap in time between these 2 lines-
                    10/15/2009 8:06:13 PM: Leave Exec: False, sirius.skin, ONSONGSTART, False
                    10/15/2009 8:07:49 PM: WM_POWERBROADCAST: wParam=6
                    That's when it was hibernating.
                    I also attached my rr.ini file
                    please look at the attached and see if you can help.
                    Chris
                    Chris Krug
                      helllllpp meeeeee pleeeassseeeee pleaseeeee helllp meeeeeeee
                      Chris Krug
                        there is NO hibernation at all happing... RR is unaware the machine is going into hibernation
                        10/15/2009 8:06:13 PM: Que Exec: True, sirius.skin, "ONSONGSTART", False
                        10/15/2009 8:07:49 PM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
                        if u notice, 8:07:49 is a RESUME... but it never was told about the hibernation
                        solve that, and u solve your problem!
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          here is what it looks like
                          10/18/2009 1:06:21 AM: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
                          10/18/2009 1:06:21 AM: PrepareForHibernate: (Start)
                          10/18/2009 1:06:21 AM: Enter Exec: False, sirius.skin, "ONSUSPEND", False
                          10/18/2009 1:06:21 AM: Que Exec: True, sirius.skin, "ONSUSPEND", False
                          10/18/2009 1:06:22 AM: Leave Exec: False, sirius.skin, ONSUSPEND, False
                          10/18/2009 1:06:23 AM: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
                          10/18/2009 1:06:24 AM: PrepareForHibernate: (After radio power's)
                          10/18/2009 1:06:24 AM: PrepareForHibernate: Event/File Flush (end sub)
                          10/18/2009 1:07:24 AM: WM_POWERBROADCAST: wParam=10
                          10/18/2009 1:07:24 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
                          10/18/2009 1:07:24 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
                          10/18/2009 1:07:24 AM: ---------------------------->
                          10/18/2009 1:07:24 AM: ResumeFromHibernate: (start)
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            i have "rr is aware of hibernate blah blah bla" checked off, what else could it be? I see windows hibernating, why wouldn't RR know? I'm struggling here.......
                            Chris Krug
                              becuase the OS isnt telling RR or prob any application for that matter
                              how are u going into hibernation?
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
