picture slide show
  • picture slide show
    Hi there
    I am trying to see my picture as a slide show
    I am using RR latest version end tray to use 2 different skin
    When I am using the Carwings Dynamic Lite skin I can see the picture but donít have the possible of the slideshow
    When I am using the DigitalFX 4.0 on the picture screen I canít see the picture but I can see that the file name in change
    What I am doing wrong ?
    the slide show really is just a skin feature.. carwings doesnt have it, but you can add it. the issue on DFX is probably a skin configuration issue.
    Ride Runner RR's Myspace
      how can i do it ?
        This is only for CARWINGS
        Put this in picviewer.skin BEFORE the "END" line:
        Code:
        L55,332,15,399,301,255,255,255,28,"Arial:B","EXEC;BYVAR;SLIDEON;SETVAR;SLIDEON;1<<SETVAR;SLIDEON;0||=SLIDE",""
        TMR,3
        and this in exectbl.ini (anywhere):
        Code:
        "TIMER","BYVAR;SLIDEON;<<DOWN",picviewer.skin
        When you click the "SLIDE" label it will show each pic for 3 secs, until you click SLIDE again to stop.
          thanks it's working fine
            does it work? i want to make a side show myself, but i am afraid it is so complicated
              working very good
                It's not "so" complicated Just copy/paste the lines above into the two skin files (Notepad will do) and you're done -- just remember this is for carwings (Other skins may have their own slide function already).
