Make RR work on stock BMW monitor
  • Make RR work on stock BMW monitor
    Hello,
    i want to know is there some possibility to make RR start like CarX?
    I'll explane; when carx start and there is right ibus code(default BMW_TAPE=68043B460C1D
    BMW_TAPE_Alternative=54415045) carX display on monitor(i have to switch on cd or tape to have video signal)
    How i can do this also to RR? I downloaded ibusRR V2, do this program switch video signal?
    Thank you very much!
    you will need to edit the IbusRR.ini file and add those commands to it's list
    ie
    ;Switch on tape
    [ID:TAPE_ON]
    MsgTemplate="68043B460C1D"
    TTR=2
    ;Switch Tape alternative
    [ID:TAPE_ALTERNATIVE]
    MsgTemplate="54415045" 'are you sure this is the right code?
    TTR=2
    You will then need to then either add a button to a skin like so
    b,x,y,w,h,"SENDMSG;iBusRR;TAPE_ON"
    or
    add to youe exectbl.ini
    "TAPEON","SENDMSG;iBusRR;TAPE_ON"
    and to the ONSKINSTART part of exectbl.ini
    "ONSKINSTART","TAPEON"
      ie
      ;Switch on tape
      [ID:TAPE_ON]
      TTR=2
      TTR=2
      or
      Thank you very much( also for responding on your own site)
      I think the code is right, also because the signal switch on correctly.
