rr reminder and language
  • rr reminder and language
    I have question for first original of RR It show correct with many language.
    I like it. But now it show reminder popup to update
    Can I remove this popup?.Because I like 1st of riderunner.
    The 1st of Riderunner have function to config of lacal but other update not have...
    When I update to last of Riderunner But language of TAGARTIST show incorrect of language ( Thai language ) I change other font but It not show corect
    I use foobar plugin for Riderunner......
    could u send me that song, with that tag...
    pm me, and i can give u my ftp
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Ha
      i just put like 5 hours into this unicode stuff...
      and i dont know what im doing
      hehehe
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        just a FYI here,
        ID3V1 tags do not support unicode... dont even both with them if u need a unicode naming
        also, in these mp3s you sent me, the ID3V2 tags are all incomplete... there is APEV2 tags that are valid...winamp will read em, but NOT RideRunner
        need to clean up your tags
        but that wasnt the problem here, a few OLD VB6 file access code was lingering in the code still, which of course die on unicode filename
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          In regards to the reminder, you just need to update your RR and it will be gone.
          I'm looking into an easy solution for those that do not wish to upgrade.
          Ride Runner RR's Myspace
            I not good ENG.
            What the way to clean up tags?
            All Thai song cannot read TAGARTIST on new update of Riderunner.
            Please suggest me to config tagartist.
            If I do not want update rr .Can I remove reminder popup.
              Update...
              So RR connects to web and check if there is an update available?
              "Most of the users you'll see in this site are still learning specially me"
                I understand .
                on my carpc does not have internet.
                update or not update version.
                If it no popup reminder it so good..
                  no RR does NOT connect to web and check if there is an update...
                  just every 3 months after the build date, thats when you see the reminder
                  its not so much about the updates, as it about people selling carpcs with RR sw
                  but this is all going to change soon
                  mitch
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Back on this thread's subject, the problem in this case was that RR did not support ID3 tags V2.4 -- in fact not even Windows 7 and WMP12 support ID3 V2.4 yet. But with some sample files from here and some work, we added support for ID3 V2.4 into RR. I'll also be posting a FAQ about Unicode Support shortly.
                      mitch
                      So what is going to change soon???
                        We'll provide a way to disable the reminder for good for those who don't want to upgrade.
                        EDIT: The reminder can be disabled on versions 12/1/09 and newer, more info HERE
