Running RR as a Shell.
  • Running RR as a Shell.
    I would like to boot directly in RR when the PC is started, but if I press the "EXIT" button on Carwings Dynamic Lite Skin, it will go in the normal Windows XP Shell. I found with "search" may topics about running RR as shell, but they are very old. Is this feature embedded in the last RR release ? If yes, is the "Hide Desktop" feature in RR Config ? If not how I can realize my dream ?
    Thanks.
    It's a Jeep thing...you wouldn't understand !--------------------------------------------
    There's no option for this in RR. You have to change it manually in the registry.
      Or you can used El Camino's AI plugin shell.exe to switch between RR or explorer.exe as a shell.
      Drop .exe into $rrpath$\Plugins\ElcoShell\
      Create buttons in the skin you are using and use the following commands:
      Code:
      "RUN;$rrpath$\Plugins\ElcoShell\Shell.exe|RR"    - RR as the systems shell
      "RUN;$rrpath$\Plugins\ElcoShell\Shell.exe|windows"    - explorer as the systems shell.
      Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
        Originally posted by Sal R. View Post
        Or you can used El Camino's shell.exe to switch between RR or explorer.exe as a shell.
        Thanks... any user manual about it ?
          Updated post w/ instructions and an updated shell.zip that works with RideRunner. Previous shell.zip was for RoadRunner
            Thank you...i will try !
              tested and works great. The only problem is, due to I use Xport, if I run RR as shell, xport will not start.
                You'll have to start xport "ONSKINSTART" or the rr.ini setting startcommand=XPORT using the custom commands defined in ExecTbl (skin or rrpath).
                i.e.
                ExecTbl.ini
                "ONSKINSTART","RUN;<path to xport>\xport.exe"
                "XPORT","RUN;<path to xport>\xport.exe"
                  Just curious, what's the point of running rr as a shell if you are still wanting to run a different shell? System resources?
                  Former author of LinuxICE, nghost, nobdy.
                  Current author of Automotive Message Broker (AMB).
                  Works on Tizen IVI. Does not represent anyone or anything but himself.
                    he would'nt need Shell if he met Lynn..lol
                    OPPS Im a MS boy.. thats was an no, no..lol
                    Did it.. Done it... now I got to keep the neighbors kids away!!
                      Have an open mind here people!
                      It may actually be Bruce that he wants to meet
                      My Fiero Build Thread
                        "SHUTCONTROL","RUN;C:\program files\shutcontrol\shutcontrol.exe"
                        "ONSKINSTART","RUN;C:\program files\shutcontrol\shutcontrol.exe"
                        don't autostart what am I missing?
                        * I got it got to addit to rr.ini then Extbl..lol, now it's above RR when it launched how do i keep it in background..
                          You can try RUNQ instead of RUN, but it may or may not work depending on the application.
                          Ride Runner RR's Myspace
                            If the above doesn't work, you might have to use AutoIt to run your application w/ the @SW_HIDE or @SW_MINIMIZE parameter to keep the app hidden.
                            Another thing you can do is add this command to ONSKINSTART:
                            SETTOPMOST;Ride Runner;True
                            ...to make rr "always on top"
