Windows crash when start RR, how to debug?
  • Windows crash when start RR, how to debug?
    Sometimes when start the RR, windows XP crash and restart again and again. This happen recently after I configed the winamp with ASIO output. The winamp version is 5.13, my new sound card is EMU USB 0404 and the out_asio.dll is from here http://otachan.com/
    After the windows restart, it report that there is a dump. I suspect that it was caused by the asio plugin, but how to prove it? Anybody can read the dump? any suggestion to a stable asio plugin for winamp?
    dont use asio for a a few times
    any real reason using ASIO, NO NEED FOR low latency audio in a carpc, its pointless
    is there a normal wdm driver?
    update winamp to something modern (5.13 is very old)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      In general, no "Application" causes windows to crash -- sure applications may crash but that will only close the application. Only DRIVERS can make windows crash - so definitely some DRIVER that RR/Winamp is using (audio/graphics/etc) is causing windows to crash. I would suggest following mitch's suggestion: Try a different audio DRIVER and/or a newer Winamp.
      Ride Runner RR's Myspace
        Yes, low latency is not necessary for me. I want to use the SPDIF output of the EMU0404. Have not found a driver other than ASIO to support it.
        Found a post http://www.audioasylum.com/forums/pc...s/2/28294.html
        The guy said " In order to use S/PDIF with the E-MU 0404 USB, ASIO must be used in the playback software"
          just using SPDIF? are you using the analog also?
          if just spdif... dump that thing, and get a simple usb to spdif
          one based on a TI PCM2xxx
          that box is way overkill
          and you're stuck with custom drivers
          on ebay, tons of TI PCM options cheap, and really nice stuff
          seach "usb spdif"
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
