Issue after upgrading
  • Issue after upgrading
    Hi folks,
    This evening I upgraded to the Nov09 release .. from the Oct 09 release.
    One thing I cannot figure out is on my directory list in background browser. I have this code ..
    /, Directory Format
    SD,00,00,30,30,"$BACKGROUNDPATH$","*.jpg",0
    /, iList Support
    IL,DL,transparent.bmp,sel.bmp,end.bmp,2,50,60
    but no matter what I do, it displays a windows media player icon on the left of the DL.
    In my logos screen I have ..
    /, Directory Format
    SD,00,00,30,30,"$SKINPATH$LOGOS","*.png",0,,,,,,,
    /, iList Support
    and it does not display any icons on the left of the list ... nor does it display icons on the audio browser screen ... ONLY the background browser screen.
    Also I have the "show icons" check box turned off in RR.ini ..
    Any ideas please ?
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    You're specifiying icons of 30x30 to be displayed (SD definition). In any case, if you disable the show icons option, then it should not matter.
    Please open RR.INI (DIRECTLY) and verify you have showicons=false -- and that you only have 1 showicons= line in the whole file. Please note that not having a showicons= line is the same as having showicons=true (which is the default).
    Also note that showicons is a global option -- having it OFF will disable icons on ALL lists -- not just the folder list.
    Ride Runner RR's Myspace
      Yes in RR.ini there is only one showicons andit is set to false.
      I did try setting the icon size to 00,00 in the SD but that did not good either.
      One other thing I've noticed is that there are two icons being added to my skin folder - these are called media.gif and folder.gif - i've no idea where these are coming from. Everytime I delete these they get recreated as soon as I load the skin again.
        Basically, iLists should work just like standard lists, if icons are supposed to show, they should show even if using the internal (default) icons -- those are the ones you're seeing being created in the skin folder. Note that previous versions did not have enough support to use the internal icons (as it should), so this could have caused icons to not show (when they actually should show).
        I have your skin Teknik 4 installed here, if that's where you're having the issue, please post the updated .skin files (and images if changed) for those two screens and I'll give it a try to see.
        EDIT: Just tried teknik4 and there seems something wrong as icons are showing (only in the two screens you made) even with showicons=false. I'll take a look at it.
          Hi there,
          here are three skins ... audio browser, backgrounds and logo's. Sorry about this guino but this is happening on both the backgrounds screen and the logo's screen.
          I've also included the rr.ini file that is on the system.
            I figured out the issue using the standard teknik4 skin (already installed here), the problem was related to using ilists on custom screens with dirlists. I have fixed it for the 12/1 release.
            EDIT: for those using showicons=true, you may want to provide a "default" icon used for the background/logo screens (i.e. an "image icon")
              so is there anything I can do with the Nov 09 version to correct the issue, or do we need to wait for the next release ?
                ah, december is but a day away... u prob can wait
                heheheh
                -Thanks
                Mitch
                www.rush2112.net
                Sun, Come shine my way
                Wind, Carry me home
                The piece of me that died
                Will return To live again
                  ah sure I suppose you're right mitch ... man where has november gone to ???
                    I don't know...but look...ah too late, its gone now...
                    Next in line: RRMedia v2.0
                    DFX 5.1.1 Skin
                    Appstore Link
                    My RideRunner Plugins
                    RRMedia
                    RRExtended
                    DFXVoice
