RR 12/01/09 Release
  • RR 12/01/09 Release
    *** Available now from HERE ****
    This release is mainly fixes and improvements, along with the support to disable the reminder screen permanently (as described HERE).
    Thanks to Blue for Updating the Skin Editor and Weather Support.
    Thanks to Mitch for Updating Vis and HD radio support.
    Thanks to all of you that provided bug reports, suggestions and feedback.
    Many thanks to all of you that worked on skins and plugins
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    12/01/09
    # Added prevention against initial drawing of labels
    # Fixed issue where iList would not always scroll on first load
    11/30/09
    # Fixed showicons setting for iLists on custom screens
    + Added way to hide icons using SD definition (even when showicons=true)
    11/27/09
    + Added support for more Visualizations to Foobar2000 player plugin
    * Improved iLists so unused space is always transparent
    11/25/09
    * Updated SkinTool to v2.1 (Exe & PI)
    * Fixed weather, loads cached info if no inet and files exist
    * Fixed weather, out of bounds error
    * Updated weather documentation
    * Updated RRConfig, transparentvis setting not saving
    11/23/09
    * Allow click through on vis windows that are set for transparent (transparentvisu=true)
    11/15/09
    # Fix to transparent selection bar on text mode ilists
    * Updated the SkinEditor to ver 0.76d
    11/13/09
    # When OS is set to use "," as decimal symbol, HD Radio will tune
    11/9/09
    # Foobar Player detects EQ Slider Sizes correctly
    Ride Runner RR's Myspace
    Thanks guys for your hard work .
    But running the reg toll it says that MSWINSCK.OSX is missing ?!
      If you get a missing OCX error with the reg tool, please Download it HERE
        A big update ,
        thanks
          Works now, thanks .
            cheers guys , great work as usual, also tryed your new regRR,not that i have ever seen the reminder screen , but thought i'll do it anyway, that is 1 hell of a reg. number to add to the rr.ini lol....
            Riderunner / Genesis
            Wifiman_NET:Version 1.0.0
              I can't keep up with these updates!
              Thank you guys for your hard work!!!
                thanks for the fixes guys ...
                The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
                  big woot for the reminder screen! and as always THANK YOU!
                    Thank you very much for this reminder screen change, guino!
                    I understand what was behind it, but it didn't really make sense for me (and I believe for a lot of us). Personally I do not install anything new to my CarPC, its software and especially hardware configuration is pretty stable, and I am absolutely happy with the version of RideRunner, which was installed quite a while ago. It's been working fine for me, and did not require update, if only not that reminder.
                    Now you made me, and I'm sure, many other people, very happy! Thanks a lot!
                    [Got keys, and a keyboard, and gone outside to install this important update...]
                    D945GCLF2, Atom 330, M2-ATX, EBY-701, Pharos GPS-500... - Assembled & Installed!
                      alpax, we do fix alot of little bugs, you may not have noticed them... but alot has been fixed up in the last 3 moths
                      so its good to review the history information
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Sun, Come shine my way
                      Wind, Carry me home
                      The piece of me that died
                      Will return To live again
                        Yes, I do understand that. I meant that RR in its current state (or even 6 months ago) is/was already good enough for my use (not just good, but excellent! ). I realize it definitely did have some small bugs here and there, which you guys have been fixing, but they were not noticeable at all in my pretty simple setup, so RR did not really need an update in my case. The thing is - updating software in a car is a bit painful, so I try just to leave it if it's working fine. And now it seems to be possible.
                        Thank you guys! Keep up the good work!
                          Smashing. You guys really do put a lot of hard graft into RR, thankyou. I proper love this FE!
                          Any chance of getting the vol+/- buttons working when using GPS attenuated volume? That would be great.
                            When I run RR , I use this OnSkinStart command
                            Code:
                            "OnSkinStart","SetApps||SetCommandLabels01||SetAppLabels||SetIcons||$default$||PresetLoader||SAY;The Multimedia system is ready||SETVAR;currentgpsname;$gpsname$||SETLABEL;!MESSAGELABEL;Welcome||GPSExec||RELAYS||RRVC||RRSched_MissedCheck",menu.skin
                            With the november version , the Say command give a normal sound, but with the last version ( december), the sound is deaf , very down , after that, the sound is normal .
                            I have just tested with WMP and foobar .
