How do I make my music stay paused with iGuidance?
  • How do I make my music stay paused with iGuidance?
    I have a question that I hope hasn't already been answered. I have iGuidance running with iGnative and it is set to pause the music on voice guidance instructions. The problem is, how do I make it recognize when the music is paused to begin with and not to start it playing again? Like, I have mobilephone.net, and it will pause the music when I get a call, but if I have iGuidance navigating for me, after every voice instuction it will start the music back up. Any help on this would be greatly appreciated.
    You are never done installing a CarPC.
    Depending on what skin your using... either add/replace these two lines in the skin's Exectbl.ini
    This will only pause if not already paused, and will only resume if was not paused at start
    PHP Code:
    "IGPAUSE","SETVARBYCODE;STATUS;STATUS||EVAL;RESULT;strcomp("$STATUS$";"PAUSE")||BYVAR;RESULT;PAUSE<<"
    "IGRESUME"
    ,"EVAL;RESULT;strcomp("$STATUS$";"PLAY")||BYVAR;RESULT;<<PLAY"
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      I am using eLite Lite. I will try this and let you know if it works. Thank you very much for your help!
        Sorry about the delay, my carpc decided to just stop working. I tried to fix it, but no go, so I got a new one. I tried your suggestion, and it works. But the problem is now that it won't start the music again after it gives the instruction. Any ideas? Thanks again.
          Not sure, post a debug log. Attach the log to the post please, not paste it in the post.
          DFX 5.1.1 Skin
          Appstore Link
          RRMedia
          RRExtended
          DFXVoice
            Where do I find the debug log, or tell it to make one if need be? Thanks.
              Config, General>Pg 4
              DFX 5.1.1 Skin
              Appstore Link
              RRMedia
              RRExtended
              DFXVoice
                Here you go. I played music and made it give a voice direction, then I exited RR. Also, I included a copy of my Exectbl.ini from the skin, just in case you wanted to look at it. Thanks.
                  My bad...I have fixed the line in the code posted above. Was an error in the resume cmds.
                  DFX 5.1.1 Skin
                  Appstore Link
                  RRMedia
                  RRExtended
                  DFXVoice
                    Awesome! I will give it a shot and let you know the results. Thanks, again.
                      That did the trick! Works like a charm now. Thank you, thank you, thank you.
