Summarize FB Gauges in RR
  • Summarize FB Gauges in RR
    Let me just see if I understand correctly how this works.
    First, I should say that what I want to do is make a set of custom gauges that live with the main menu buttons (I.E. not on a special "gauges" embedded screen). This is pretty much what Batman did last year. I could track his learning progress here but there were not a lot of details posted. So I'm running Ride Runner currently with the Simplistique skin (but anticipate modifying it a bit to fit my gauges) and I intend to buy the Fusion Brain (FB).
    Is it just a matter of using the RRFusion plugin and then the FB outputs just appear in RR as variables? Then I can use those variables as input to Flash scripts like these?
    Sorry if this is too basic but I just want to understand the fundamentals. I'm totally new to RR, FB, Flash, and even Windows (I'm a programmer by profession, just not in these areas).
    thanks,
    Dave
    http://www.evalbum.com/2500
    almost no reason to burn gasoline anymore
    You seem to have the right idea.. from flash you'd be executing the command fscommand("GETLABEL;ANALOG0RAW") and you'll have the flash variable ANALOG0RAW set in flash for you to use however you want..
    Ride Runner RR's Myspace
