Playlist creation
  • Playlist creation
    I'm trying to create a button that will auto add music in a directory to a playlist.
    Heres what I have come up with.
    If I create a batch file (Hidden attribute) and use this
    Code:
    @echo off
    dir /o:n /b /A-H *.* > "C:\MUSIC\playlists\ALTROCK.m3u"
    It will create a playlist called ALTROCK.m3u
    Unfortunately it will not open with Winamp, just WMP.
    Winamp adds
    "#EXTM3U""
    "#EXTINF: ID TAG"
    "PATH\Filename"
    Without creating it manually with Winamp or using a 3rd party application, I cant seem to do this.
    Anyone know if this is possible?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    The playlist without the #EXTM#U and #EXTINF lines should work fine in winamp as long as the lines have the FULL drive+path+filename -- I know this for a fact because RR itself will create this types of playlists for using with winamp. The file created by the command you posted will likely only have the FILENAMES (without drive or path) -- they should work as long as the playlist file is in the same folder with the files.
    You can create the playlists in RR or make some sort of script (or more complex command) to do what you're looking for .. for instance:
    Code:
    del /y ALTROCK.M3U
    for %f in (*.mp3) do echo %cd%\%f%>>C:\MUSIC\playlists\ALTROCK.M3U
    Ride Runner RR's Myspace
      Code:
      del /y ALTROCK.M3U
      Thanks Guino,
      Here's the code I used.
      Code:
      del /y C:\MUSIC\playlists\ALTROCK.m3u
      for %%f in (*) do echo %cd%\%%f>>C:\MUSIC\playlists\ALTROCK.m3u
      When I load up a list of songs in winamp, close RR, and it loads winamp, the previous songs are loaded still. What list is it loading? Do you know the location of this?
      I thought it was
      C:\Program Files\winamp\winamp.m3u
      This file doesnt seem to exist.
      Any clue?
        winamp NOW (if u using a new version since 5.3x) stores its data, AS IT SHOULD, in the USER PROFILE!!!
        in windows7/vista, winamp stores its data:
        C:\Users\mitchjs\AppData\Roaming\Winamp
        with your name in there
        i havent used xp in a long time, so its in some %appdata% dir
        now, when rr loads, we load rrpl.m3u8
        not by chance using DXF4?
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          Naa, Im using my own version of BM skin. Thanks for the info! Now.. back to editing/testing.
