Send a variable from autoit to rr
  • Send a variable from autoit to rr
    I try to create a little autoit program who sen to RR a variable :
    Code:
    $rr.execute("SETVAR;Myvar;1800")
    With skin tool a see well that Myvar = 1800.
    In a skin , i want to see in a label code the varial resul , 1800.
    How can i write my ligne in my skin file please !
    Thanks for any help !
    Thanks Enforcer,
    And if i want that my label code is :
    Code:
    L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","TEST",
    What must to be my command in autoit do define my variable ?
    Code:
    $rr.execute("SETVAR;????????;1800")
      Originally posted by Enforcer View Post
      Code:
      Code:
      L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","=$myvar$",
      Yes Enforcer, I have tried your example and that's ok .
      But I should like to have in my skin that :
      Code:
      L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","myvar",
      What must to be my script command please ?
        That is the correct way: L,.......,"Lucida Sans Unicode:B","=$myvar$",
        The only other way is to do: L,.......,"Lucida Sans Unicode:B","CUSTOMxxxxxx",
        You just put 'CUSTOM' in front of whatever you want to call your label.
        Then your scrip just uses the cmd: $rr.execute("SETLABEL;CUSTOMxxxxxx;Wazaaap!")
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          You can also do these variations:
          Code:
          L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","$myvar$",
          with command:
          $rr.execute("SETVAR;Myvar;=1800")
          OR
          Code:
          L,593,313,137,21,255,255,255,12,"Lucida Sans Unicode:B","!MyVar",
          with command:
          $rr.execute("SETLABEL;!Myvar;1800")
          (! is the same as "CUSTOM" -- but it may not work on all languages).
          You can NOT do this:
          Code:
          Because that is saying that the label should display a LABEL CODE called "myvar" which can only be an internal label code or a label code defined in an extension plugin.
          Ride Runner RR's Myspace
            Thanks Blue , thanks Guino.
            It's excately that i wanted to know !
              Hi Guino,
              I try to create a new program who send two variables to RR;
              I have tried that:
              Code:
              $rr.execute("SETVAR;CUSTOM_GMAILMESSAGE;YOU HAVE SEVERAL MAIL !!!")
              $rr.execute("SETVAR;CUSTOM_GMAILNUMBER;"&$a)
              with this line on my skin file:
              Code:
              L,19,48,411,169,255,255,255,30,"Arail:B","CUSTOM_GMAILNUMBER","CENTER"
              L,11,8,427,25,0,0,0,20,"Arial:B","CUSTOM_GMAILMESSAGE","CENTER"
              and also
              Code:
              $rr.execute("SETVAR;!GMAILMESSAGE;YOU HAVE SEVERAL MAIL !!!")
              $rr.execute("SETVAR;!GMAILNUMBER;"&$a)
              Code:
              L,19,48,411,169,255,255,255,30,"Arail:B","!GMAILNUMBER","CENTER"
              L,11,8,427,25,0,0,0,20,"Arial:B","!GMAILMESSAGE","CENTER"
              Skintool see well my two variables but when i load my screen, nothing appear .
              I have tried these lines to finish:
              Code:
              $rr.execute("SETVAR;GMAILMESSAGE;=YOU HAVE SEVERAL MAIL !!!")
              $rr.execute("SETVAR;GMAILNUMBER;"=&$a)
              Code:
              L,19,48,411,169,255,255,255,30,"Arail:B","$GMAILNUMBER$","CENTER"
              L,11,8,427,25,0,0,0,20,"Arial:B","$GMAILMESSAGE$","CENTER"
              And it is ok for me .
              So the two first option don't run for me !
                In autoit
                Code:
                $rr.execute("SETVAR;CUSTOM_GMAILMESSAGE;YOU HAVE NEW MAIL!")
                $rr.execute("SETVAR;GMAILNUMBER;" &$a)
                In your skin
                Code:
                L,19,48,411,169,255,255,255,30,"Arail:B","=$CUSTOM_GMAILMESSAGE$","CENTER"
                L,11,8,427,25,0,0,0,20,"Arial:B","=$GMAILNUMBER$","CENTER
                  You can use MGD's solution OR one of these two:
                  Code:
                  $rr.execute("SETLABEL;CUSTOM_GMAILMESSAGE;YOU HAVE SEVERAL MAIL !!!")
                  $rr.execute("SETLABEL;CUSTOM_GMAILNUMBER;"&$a)
                  with these lines on the skin file:
                  Code:
                  and also
                  Code:
                  $rr.execute("SETLABEL;!GMAILMESSAGE;YOU HAVE SEVERAL MAIL !!!")
                  $rr.execute("SETLABEL;!GMAILNUMBER;"&$a)
                  Code:
                  What you posted didn't work because you were using SETVAR instead of SETLABEL.
                    Thanks Guino
                      Can you explain me how can i use the "IND,SHUFFLE,Indicators\Shuffle_off.png,Indicators \Shuffle_on.png" option with an AutoIt script and a skin.
                      If i understand well , i can have that:
                      Code:
                      But how to define the x y positions for my indicators in my skin file and how i call it in my autoit script ?
                      Thanks for your lights
                        It should be:
                        Code:
                        I01,100,100,200,200,"!myind"
                        (The IND line must be BELOW the line of the indicator -- but doesn't "have" to be the very next line to it).
                          Ho i see,
                          Code:
                          I01,100,100,200,200,!myind
                          or
                          Code:
                          Thanks Guino
