Ride Runner and Windows 7 32bit
  • Ride Runner and Windows 7 32bit
    OK i just installed a new board (intel d510mo) with 2gb ram and a 250gb sata drive. My old board crashed. So, I after installing windows and all updates, I installed ride runner and it doesn't work. I used the config screen and changed everything like I had it on the old computer running xp. I go and open ride runner and get the following message:
    Ride Runner Car Entertainment Center has stopped working
    Windows can check online for a solution to the problem.
    Check online for a solution and close the program
    Close the program
    Debug the program
    I have done all three and everytime I start riderunner i get this message. I have tried the default skin and elite lite neither one gets me past this point. I know people are using windows 7. How do I fix this?
    can u make a debug log ? since you're using windows 7 - did you install .NET for the audio mixer support ?
    Ride Runner RR's Myspace
      i don't know how to make the debug log and i just installed the new ride runner release thats it.
        2/17/2010 9:11:53 PM: Start -- Version: 2/1/2010
        2/17/2010 9:11:53 PM: OS Type: Windows 7
        2/17/2010 9:11:53 PM: FileManager: FileMode = Legacy
        2/17/2010 9:11:53 PM: FileManager: mypath = C:\Program Files\RideRunner\
        2/17/2010 9:11:53 PM: FileManager: ProfilePath = C:\Users\CarPC\Documents\RideRunner\
        2/17/2010 9:11:54 PM: VMC---> Set object successful
        2/17/2010 9:11:54 PM: VMC---> SOURCE: Playback Input line #1: "Speakers"
        2/17/2010 9:11:55 PM: PLAYER: Winamp Version:
        2/17/2010 9:11:55 PM: DirectDraw Count: 1 - []
        2/17/2010 9:11:55 PM: No Phidgets interface detected.
        2/17/2010 9:11:55 PM: Plugin Manager: loading Global Plugins...
        2/17/2010 9:11:55 PM: Plugin Manager: Plugin Found: SkinTool
        2/17/2010 9:11:55 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
        2/17/2010 9:11:55 PM: Plugin Manager: Plugin loaded (Global): SkinTool
        2/17/2010 9:11:55 PM: Plugin Manager: Plugin Found: Weather
        2/17/2010 9:11:55 PM: Plugin Manager: Plugin loaded (Global): Weather
        2/17/2010 9:11:55 PM: Plugin Manager: loading Global Plugins Completed.
        2/17/2010 9:11:55 PM: LoadSkin: C:\Program Files\RideRunner\Skins\Carwings_Dynamic_Lite\
        2/17/2010 9:11:55 PM: Plugin Manager: loading SkinDir Plugins...
        2/17/2010 9:11:55 PM: Plugin Manager: loading SkinDir Plugins Completed.
        2/17/2010 9:11:55 PM: ERROR: Loading image file(s) for: menu.skin (Failed to load control
          2/17/2010 9:21:24 PM: Start -- Version: 2/1/2010
          2/17/2010 9:21:24 PM: OS Type: Windows 7
          2/17/2010 9:21:24 PM: FileManager: FileMode = Legacy
          2/17/2010 9:21:24 PM: FileManager: mypath = C:\Program Files\RideRunner\
          2/17/2010 9:21:24 PM: FileManager: ProfilePath = C:\Users\CarPC\Documents\RideRunner\
          2/17/2010 9:21:24 PM: VMC---> Set object successful
          2/17/2010 9:21:24 PM: VMC---> SOURCE: Playback Input line #1: "Speakers"
          2/17/2010 9:21:25 PM: PLAYER: Winamp Version:
          2/17/2010 9:21:25 PM: DirectDraw Count: 1 - []
          2/17/2010 9:21:25 PM: No Phidgets interface detected.
          2/17/2010 9:21:25 PM: Plugin Manager: loading Global Plugins...
          2/17/2010 9:21:25 PM: Plugin Manager: Plugin Found: SkinTool
          2/17/2010 9:21:25 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
          2/17/2010 9:21:25 PM: Plugin Manager: Plugin loaded (Global): SkinTool
          2/17/2010 9:21:25 PM: Plugin Manager: Plugin Found: Weather
          2/17/2010 9:21:25 PM: Plugin Manager: Plugin loaded (Global): Weather
          2/17/2010 9:21:25 PM: Plugin Manager: loading Global Plugins Completed.
          2/17/2010 9:21:25 PM: LoadSkin: C:\Program Files\RideRunner\Skins\eLite Lite\
          2/17/2010 9:21:25 PM: Plugin Manager: loading SkinDir Plugins...
          2/17/2010 9:21:25 PM: Plugin Manager: loading SkinDir Plugins Completed.
          2/17/2010 9:21:26 PM: ERROR: Loading image file(s) for: menu.skin (Failed to load control 'Flash' from . Your version of may be outdated. Make sure you are using the version of the control that was provided with your application.)
          Since this one isn't working on this computer I tried to install it on my laptop using windows 7 64bit and everything works fine. Used all the same files I used to install on this computer
            as you can see from this line:
            It is complaining that you do not have the latest version of Flash installed. Try updating and see if it helps.
              will do - thanks
                flash installer is on a sticky in this forum
                http://www.mp3car.com/vbulletin/road...sh-10-now.html
                -Thanks
                Mitch
                www.rush2112.net
                Sun, Come shine my way
                Wind, Carry me home
                The piece of me that died
                Will return To live again
                  now I get this:
                  2/18/2010 7:47:53 PM: Start -- Version: 2/1/2010
                  2/18/2010 7:47:53 PM: OS Type: Windows 7
                  2/18/2010 7:47:53 PM: FileManager: FileMode = Legacy
                  2/18/2010 7:47:53 PM: FileManager: mypath = C:\Program Files\RideRunner\
                  2/18/2010 7:47:53 PM: FileManager: ProfilePath = C:\Users\XRunner\Documents\RideRunner\
                  2/18/2010 7:47:53 PM: ERROR: GDI+ support is requested, but unable to create object, possible cause, 'GDIPlusWrapper.dll' is not registerd
                  2/18/2010 7:47:54 PM: VMC---> Set object successful
                  2/18/2010 7:47:54 PM: VMC---> SOURCE: Playback Input line #1: "Line In"
                  2/18/2010 7:47:54 PM: VMC---> SOURCE: Playback Input line #2: "Microphone"
                  2/18/2010 7:47:55 PM: DirectDraw Count: 1 - []
                  2/18/2010 7:47:55 PM: No Phidgets interface detected.
                  2/18/2010 7:47:55 PM: Plugin Manager: loading Global Plugins...
                  2/18/2010 7:47:55 PM: Plugin Manager: Plugin Found: SkinTool
                  2/18/2010 7:47:55 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
                  2/18/2010 7:47:55 PM: Plugin Manager: Plugin loaded (Global): SkinTool
                  2/18/2010 7:47:55 PM: Plugin Manager: Plugin Found: Weather
                  2/18/2010 7:47:55 PM: Plugin Manager: Plugin loaded (Global): Weather
                  2/18/2010 7:47:55 PM: Plugin Manager: loading Global Plugins Completed.
                  2/18/2010 7:47:55 PM: LoadSkin: C:\Program Files\RideRunner\Skins\eLite Lite\
                  2/18/2010 7:47:55 PM: Plugin Manager: loading SkinDir Plugins...
                  2/18/2010 7:47:55 PM: Plugin Manager: loading SkinDir Plugins Completed.
                  2/18/2010 7:47:55 PM: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (main.png)
                  2/18/2010 7:47:55 PM: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (menus.png)
                  2/18/2010 7:47:55 PM: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (on.png)
                  2/18/2010 7:47:55 PM: ERROR: Loading image file(s) for: menu.skin (Invalid picture)
                  2/18/2010 7:48:05 PM: Shutdown: (1)
                  2/18/2010 7:48:05 PM: Shutdown: (2)
                  2/18/2010 7:48:05 PM: Shutdown: (3)
                  2/18/2010 7:48:05 PM: Shutdown: (4)
                  2/18/2010 7:48:05 PM: Plugin Manager: ALL Plugins unloaded.
                  2/18/2010 7:48:06 PM: Shutdown: (5)
                  2/18/2010 7:48:06 PM: Shutdown: (6)
                  2/18/2010 7:48:06 PM: Shutdown: (7)
                    If you used the installer then you should have everything you need... you probably just need to open RRConfig, go into General->Page 2 and make sure that "screen fast mode" is selected to "GDI+".
                      I used the new version of rr that came out this month and gdi+ is checked. still same error. maybe i should just go back to xp and see if that works.
                        bump for help/suggestions
                          Post a zip of your rr.ini and your skin.ini (frm elite skin) so I can take a look at it.
                            ok at work right now will attach when i get home
                              Here is the two files I am using.
