HORM and Resuming music
  • HORM and Resuming music
    I have done lots of searching and reading and tried everything but I can't get RR to resume playing music.
    I am using DFX4 with winamp 2.95.
    RR saves correctly to the HORM drive but when the computer resumes I can tell RR is trying to resume the playlist but never loads anything. The playing status bar shows full and then blank and full again. If I goto music the loaded playlist is RRPL. I took a look at the horm cache and it has the correct playlist saved. It just won't load that on resume.
    I haven't had a chance to turn on debug to see what is happening. Where doesn't is save the debug file? Since it would be lost anyway with EWF.
    Any idea's, maybe someone has seen this before?
    Thanks.
    FKA psptibby
    It should copy the debug.txt from before shutting down onto debug_shutdown.txt in the horm drive. When resuming it should continue with the debug.txt file in RR's folder.
    Ride Runner RR's Myspace
      So I just need to enable debug in the ini correct? Is there a option in RRConfig for that? I can look after work.
      FKA psptibby
        make sure u remove the kill winamp in DX4
        this is a ongoing issue!!
        there are plenty of threads on it
        look in exectbl... i dont know exactly...
        but im not sure its a issue here...
        yes RRCONFIG page 4
        debug and debug fresh
        also because you dont provide info, I say it again, use the NEWEST RideRunner
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          Ah...mitch showing some more dfx4 love...
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            I will take a look, I didn't find anything in the exectbl, but i will do some searchs and see what i come up with.
            Sorry about that I am using the lastest verison, just rebuilt it with cf in the last few weeks. I was looking for another skin but just can't anything aas featured filled as DFX4. Just wish there was something newer. Seems like there isn't as much activey compared to a few years ago when is started all this, probably 05.
            FKA psptibby
              I found the killwinamp entry, so on my way home today will be the test if it resumes. I think it will work.
              FKA psptibby
                it didn't work, i am going to try it again.
                FKA psptibby
                  debug....
                  try another player too
                  WMP
                  and use carwings_dynamic_lite
                  get it working there
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Try reformatting your horm drive and reseting the hibernation point.
                    I've run into this issue a few times where the cache is being saved, but not resuming.
                    S
                    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
                      hey, there is my HORM boy
                      Sal, hope all is well
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        All is good. Just got back into town after a series of traveling for work.
                        Ready to get back to carPC'ing...
                          So I tired WMP and it loaded the list but always started at the top. Also it seems like net radio on DFX4 didn't work. Attached is my debug file. I can post it again after a few cycles if that helps.
                          FKA psptibby
                            S
                            I can try that, but I see the cache folder and I have deleted it and it comes back. I looked at the files and it has the proper previous play-list.
                            It seams like it tries to reload it.
                            FKA psptibby
                              net radio is prob a winamp only thing...
                              i did say it before, use carwings_dynamic_lite
                              and test horm...
                              can be 100% sure of dfx4.... specially if you didnt remove the winamp kill
                              mitch
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
