No MP3 association with Winamp
  • No MP3 association with Winamp
    Hello,
    If I click on a MP3, it's not getting transferred anymore to Winamp and thus is not playing. The file associations in Winamp are set, the file associations in Windows itself are set to Winamp and also are they set in the RR config.
    .m3u and .pls files are transferred correctly.
    What to change?
    Thanks.... Porto
    What happens when you click on a mp3 ? nothing ? another program opens ?
    Regardless of anything, RR should work with mp3s without any problem.
    Ride Runner RR's Myspace
      Hello Guino,
      No, nothing happens. It just throws me back to the root of my MP3 directory as configured in the RR config file.
      I then have to click on the 'Browser' button again to give me the list where
      I can select a specific MP3 which I can doubleclick to play.
      It have worked before but I had to install and configure the system from the ground up (HDD issues) and since then it didn't work anymore.
      If I configure Mediaplayer the MP3's are working again but I would miss the visuals, equalizer settings (mixer) and the Internet Radio.
      Also, when using Mediaplayer, RR often hangs on the startup screen for multiple minuts before I get the main menu, so it's not an option for me.
      Thanks for the help..
      Porto
        It seems you're talking about different things here.
        I suggest you do this:
        1-Open Winamp (OUTSIDE RR -- WITHOUT RR RUNNING) load some songs and verify it works without using RR.
        2-Open RRConfig and select Winamp as the player :: BE SURE To point it to the winamp path manually.
        3-Open RR and try it. If "1" worked, then it should work in RR.
          Hello Guino,
          Outside RR winamp is playing MP3's perfectly when I doubleclick on them.
          RR is executing Winamp in the background but only uses it for .m3u and .pls files as needed with Internet Radio. I tried to configure winamp on Automatic and Manual startup.
          But.... if I execute RR and winamp is running in the background... then if doubleclick a MP3 in Explorer the file plays within winamp. Now, If I go back to RR, go to the main menu and back to 'Music' again, I see the trackalbum, artist info etc in the header of RR's main menu (DFX4 skin). So, RR is seeing the track being played in winamp but won't let me play one from within RR itself to winamp. %-/
            you do have .mp3 as a file type for music right?
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
              yes, checked, checked and double-checked it to be very sure!
                can you post your rr.ini so we can take a look ?
                  Here is my RR.ini file.
                  Please tell me if something doesn't seem alright in it.
                  Winamp is physically installed where the rr.ini file says it is.
                    hmmm
                    .zip it next time
                    prob doesnt like
                    .ini
                    or make it
                    .txt
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Guess I'm not the only one that has installed WA right in the RR folder...hehehehe Makes backing up a RR setup very easy.<br>Surprised that mitch didn't have a problem with that..
                      Next in line: RRMedia v2.0
                      DFX 5.1.1 Skin
                      Appstore Link
                      My RideRunner Plugins
                      RRMedia
                      RRExtended
                      DFXVoice
                        Sorry Mitch, have made it a .txt file and attached it this time...
                          its NOT a UAC violation, as long as its a new winamp
                          > v5.3
                          soo.. i cant find anything wrong with it...
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            proto, by now i cant remember what the actuall problem is?
                            are u testing with CARWINGS?
                            you could post a debug.txt of a session... i dont know what it will show us
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              What is an UAC???
                              I think I use a Winamp above v5.3 but I'll check asap (am not at home right now).
                              However, I didn't test the problem yet with Winamp installed in the default folder; I'll try that.
                              I didn't test with another skin, I'll try that also; I currently use DFX 4.0 skin.
                              As a last resort I'll re-install the lot because I just want this to work properly.
