RR 04-01-2010 Release
  • RR 04-01-2010 Release
    April Fools edition... heck I thought about saying we're going back to Road Runner... But you know...
    anyway...
    We got a new release for you of course, packed with new features(not really) and some bug fixes(yes really)
    Download from here
    Some Highlights:
    • DAB Venice5 Radio Module
    • PLabs Digital Car Radio FM Radio Module
    Thanks to Guino
    Thanks to Bluezx3!
    Thanks to Fixerofallthings (for carwings skin help)
    Thanks to Griff1, nrgizerbunny, and Andy W for all their DAB Radio Work
    Thanks to the people who test and report issues (we fix em as fast as we can, usually instantly)
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    03/31/10
    + Skin Command: "SETPATH" lock option, ex: "SETPATH;c:\mynewpath;lock"  (locks user into this path, back will not "go up")
    + Skin Command: "HOME" same as "!BROWSE" (used to return to MUSIC_PATH or VIDEO_PATH depending where at)
    03/30/10
    # Fixed "ONLINE" and "OFFLINE" events
    * Improved SEARCHFILES command to work on non-standard screens
    03/29/10
    + Venice5 DAB/FM Radio module
    + PLabs Digital Car Radio FM Radio Module
    03/28/10
    # SkinTool.dll enable not supported fixed
    # SkinEditor setting labels to bold when not told so
    + "SETVARFROMVAR" - use a variable within another variable's name
    03/26/10
    * Improved Windows 2000/XP mixer support to update mixer immediately upon outside changes
    + [WINDOWS 9x ONLY] SETTING/USERVAR: "MIXERREFRESH=x", where x = 1 to 50 (time in 10ths of a second)
      this is the rate at which mixer levels/mutes are polled from system. The default is 30 (3 seconds).
    * Removed the absolute path to skin, in resume.ini, since skins are in the "SKINS" directory
      (absolute paths have not been needed in rr.ini for a long time now, so this now matches)
    03/21/10
    ! Performace improvement: When using "Winamp Line-In Plugin" for any source; Radio, XM, Sirius, A new secondary instance of Winamp is used.
    03/18/10
    # Issue with the CTRL RIGHT/LEFT not selecting next/prev control
    # Improved iList support to auto-add non-gesture area
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks for this new version.
    I try this command:
    Code:
    "ONLINE","MENU;MessageBox.skin||SETVAR;INFOTITLE;NewMessage !!!||SETVAR;MESSAGE;YOU ARE ONLINE !!!"
    "OFFLINE","MENU;MessageBox.skin||SETVAR;INFOTITLE;New Message !!!||SETVAR;MESSAGE;YOU ARE OFFLINE !!!"
    I don't see my button labels
    If i comment the ONLINE command, i see my labels. Why ?
    But if i am offline, my ONLINE command can to be uncommented !
    I upload my MsgBox screen in case !
      the download is april
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        I try this command:
        Code:
        debug.txt, look there... also skintool, live log will show you so much...
        also... for conversational purposes
        ONLINE and OFFLINE are NOT COMMANDS, they are EVENTS
        "ONLINE" is also an indicator
        when online to offline or visaversion happens, the event is fired, only once and only when windows resports InternetGetConnectedState changes
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          just letting people know the dl is updated, and its not a March installer
          so there is no confusion
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            mitch is the fix for the sirius issue included?
              i am not aware of any sirius issue
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Was a Bug report made for the issue your talking about? If not, then is possibly why Mitch didn't know of it.
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
                  Cheers dude.
                  P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
                    Great work, is there a link to the plabs radio?
                    The epitome of Function over form and is probably the best Car PC in Europe.
                    Visit my Homepage
                      its a russian silabs clone, even google cant find it
                      http://www.digitalcar.ru/shop/produc...oducts_id=3065
                      FM only, uses same chip as all other sliabs based ones
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        I know well that ONLINE is also an indicator.
                        I want use ONLINE and OFFLINE like events to run one or several commands.
                        I upload my debug files
                          not sure why you're posting your debug, you for sure are skilled enough to review
                          nor i dont know what we are looking for
                          ONLINE
                          ONSCREENCHANGE
                          ONSOURCECHANGE
                          ONSONGSTART
                          note, that the initial online, is coming before ONSKINSTART
                          so it might not show that, but if u simulated a offline, and a following online
                          i dont know
                          there is basiclly nothing in your log with offline, to online...
                          so i would suggest you to some more tests
                          you dont need me
                          i bet if you USE SKINTOOL...
                          INFOTITLE & MESSAGE vars are set
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
