Byind & exists
  • Byind & exists
    Does anyone know if I can use the "EXISTS" dynamic indicator code with the BYIND command.
    Basically this is the code I'm trying to get working, but can't for some reason.
    "BYIND;EXISTS;$SKINPATH$TEST.BAT;=Yes<<=No"
    Thanks in advance ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    Again with these interesting mix of features..
    This should work if you don't use ";" with exists ( ; is the correct way), try using : instead:
    "BYIND;EXISTS:$SKINPATH$TEST.BAT;=Yes<<=No"
    This will LIKELY work..
    Ride Runner RR's Myspace
      Well sure there is no point in asking easy questions ...
      I really hoped that command would work, but no joy. It will work as a regular IND command but not inside the BYIND command. So back to the drawing board ... lol
      Thanks.
        This should have worked.. let me try it out and let you know..
          thanks guino.
            I think I found the issue... write the word EXISTS in lower case like (already fixed code):
            "BYIND;exisits:$SKINPATH$TEST.BAT;=Yes<<=No"
              Works perfect ... thank you sir.
                should have worked the first time too if there wasn't a sneaky bug in there..
                  Learn something new everyday w/ this FE.
                  Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
