A few 'issues'.
  • A few 'issues'.
    I've had a few problems with the last 2 releases. 3/1- the line-in will not unmute, even though I have it checked in config. I have to go into the EQ screen and click the line-in button a few times, then it stays on and works. BUT, sometimes the music (MP3's) will play along with the radio. I have to pause the MP3.
    Also, pre-load screen will not load or stay in the RR.ini after turning off the computer. I have to run config and set them again.
    With the 4/1 release, same issues but now the CPU usage is way up around 60%, as where with 3/1 it was around 10% or less.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    something on your machine....
    no major changes in the release
    why would the line-in unmute anyway? the only way it would if something asks it to
    sounds like something it writing to your rr.ini (rr wont do that on its own)
    cpu% flash issues... are u at the latest flash? see sticky
    usually 1st thing i say, is use carwings_dynamic_lite
    (this time its not the 1st thing... but still applies)
    also.. before you say i have it checked in rrconfig... id look at rr.ini directly in text editor
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      This would normally be the que for E to suggest his "notepad fix all" saying...
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        hehe, well the other day someone insisted they didnt change anything in thier skin, only to find "resumemusic" was changed in rr.ini
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Ok, I'll check it with notepad.
          As for the line-in unmuting...it should be muted when you are using the music (MP3,etc) function and then unmute when you select the HD radio. But why would the MP3's still play when I'm using the radio? Since I got the new MB, it does this but have no idea why.
          Thanks.
          Mike
          My Rides:
          '03 Vibe GT!
          My AED GA!
            Thanks.
            hard to say why(skin names is one reason)... you asking me to answer that blind folded..
            try enlighting me, post a debug.txt of the session using carwings_dynamic_lite
            and post your rr.ini
            oh, when i say post... i mean attach
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              Ok, the preload screen is fixed and so is the CPU usage issue. I thought I installed 10.
              Heres those files. I usually use DFX 4.0, but switched to the FE you asked for.
              Mike
              My Rides:
              '03 Vibe GT!
              My AED GA!
                so using carwings dynamic, going from radio to mp3s, does radio mute?
                its hard to argue with the log
                4/8/2010 10:09:42 AM: Executing: Audio
                4/8/2010 10:09:42 AM: HDRadio---> RadioActive: Active = false
                4/8/2010 10:09:42 AM: HDRadio---> RadioActive: Active = false, .MuteOn
                one thing you're using the line in plug in...
                but WMPRR, which of course doesnt have that...
                id set
                uselineinplugin=false
                thats gonna open a few issues
                maybe not... we do have some safety checks
                try that, and let me know...
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  No problem with the radio muting when going to MP3's. Just vice versa.
                  I'll try that then and let ya know. Thanks again.
                  Mike
                  My Rides:
                  '03 Vibe GT!
                  My AED GA!
                    going from mp3 to radio, should UNMUTE the radio... and i dont think you did that scenario in you debug.txt posted
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Sorry for the really late reply.
                      This still has me baffled. I just cant get it to work. It's just weird that it worked with the 2/1/10 release, but after I installed the 3/1/10 release, this started.
                      Also, what line are you refering to?
                      Sorry and thank you much for the help.
                      Mike
                      My Rides:
                      '03 Vibe GT!
                      My AED GA!
                        its been so long...
                        log with radio debug on, xm debug on...
                        log doing what you do when you think it should mute...
                        going from MP3 (AUDIO_PLAYER.SKIN) to radio (RADIO_PLAYER.SKIN)
                        must happen if you want mp3s to "pause"
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          As requested.
                          Thanks.
                          Mike
                          My Rides:
                          '03 Vibe GT!
                          My AED GA!
                            not 100% sure if this is issue, but its wrong
                            4/30/2010 10:17:50 AM: PLAYER: WMP Version: WMP (9.0.0.3364)
                            4/30/2010 10:17:50 AM: HDRadio---> Using External Audio Capture: True
                            that says to me you are using the WINAMP line in plugin, which.... is for WINAMP, not WMP...
                            change, your RR.ini setting... i should have asked for that
                            you [radio] section should look close to
                            [Radio]
                            radio=HDRadio
                            allowallfreqs=false
                            radioline=5
                            lineinpar=line://preset=HDRadio,title=Radio
                            userbds=true
                            RadioPort=3
                            HDRadioType=Directed
                            but...
                            going from radio to audio
                            4/30/2010 10:18:10 AM: Executing: Audio
                            4/30/2010 10:18:10 AM: HDRadio---> RadioActive: Active = false
                            4/30/2010 10:18:10 AM: HDRadio---> RadioActive: Active = false, .MuteOn
                            and Audio to radio... should pause WMP
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
