Run google earth dircetly by a kml file
  • Run google earth dircetly by a kml file
    I try to run Google Earth with this command:
    Code:
    "MyApp72","Load;google.skin||RUN;$PLUGINSPATH$Google\list.kml;Google Earth"
    The screen file is well loaded but the kml is not launched .
    If somebody has an idea please ?
    Code:
    That is because the GE needs to probably be opened with the file as a param. Not sure if the GE plugin can do that...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      I don't use the ge plugin in this screen .
      I should like just run ge by a kml file , as is possible directly when i double click on a kml file
        Then were is the command that your using to launch GE?
        DFX 5.1.1 Skin
        Appstore Link
        RRMedia
        RRExtended
        DFXVoice
          exactly like Blue says.. you need to launch GoogleEarth.exe and pass the KML file as a parameter -- you can NOT just tell RR to "launch" the KML file beacause it's not an executable file type.
          Ride Runner RR's Myspace
