Latest RR problem with Album art
  • Latest RR problem with Album art
    Dear all,
    The album art no longer shows on RR with recent version (I remember they used to work in 2009 release). I have read the FAQ and following the instruction to name them folder.jpg in every album folders under the artist's folder. The jpg files are all non-hidden and not read-only. I have tried different skins and all have the same problem. Please helps. Thanks in advance.
    Jguy
    approved the post
    this is for sure not the case
    you provide no real information...
    the RR version, the OS and so fourth
    Album art is working fine, if you are using the mp3art plugin, for embedded artwork.. i would uninstall that, and get the newest
    also in rr.ini
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      I am using Windows 7 32-bit, RR is the April release. It's a fresh install because I was running 64-bit of Windows 7 and I thought it's why I got problem with it. I used to able to see the album art prior to 2010 release. The jpg are not embedded and I put the image together with the MP3's. The rr.ini setting is what you're suggesting. I can post a screenshot if requires. Thanks.
      Jguy
      Originally posted by mitchjs View Post
      approved the post
      also in rr.ini
        I have this issue too. Main PC and CarPC both running RR with exactly the same skin, same version, using same mp3s with same albumart files in the same folder locations. Main PC shows album art, CarPC doesn't. And I can't for the life of me work out where the difference lies.
        http://sticksout.blogspot.com
          Be careful Mitch I have been proven wrong on a statement like that many time now hahah
          My Fiero Build Thread
            john, now now
            did u guys look at your coverfile setting in rr.ini?
            how about looking in Skin Tool, at the albumart indicator
            like
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              I have attached my rr.ini. I checked it using Skin Tool and it says contain no data at the audio player skin.
              john, now now
              like
                post a debug session too... cant even tell if media is playing
                if winamp is stopped and no track info is available, u get no albumart...
                also... post a rrpl.m3u8
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  how about some poorly programmed plugin, destroying albumart indicator
                  thats why i need to see a debug.txt of a session!
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    some questions about album art itself.
                    i see in some skins that the coder use the command....J,140,203,227,203 other use
                    I,140,203,227,203,"ALBUMART"
                    what makes the difference ?
                    i thought the >J< command will show all arts, like radio, album, aso.
                    and the >I< command will only show the "albumart"
                    that was not true. its unimportant what command i code, it shows in both the same.
                    another missunderstanding is the name "AlbumArt". as i translate it, i thought it shows me, like in older riderunner versions the pic which i integrate inside my mp3 file, if there is no pic inside...it shows the .jpg which is in the musicfolder ive opend.
                    momentary i cant see the pic which is in my musicfolder.
                    so, as i read your notes, and i see whats happend on my screen...i MUST give every mp3 file a pic, otherwise i see an empty field.
                    dont say i must give every mp3 file a pic.
                      no difference, the J gets turned into a Indicator called "ALBUMART"
                      infact i would say the I command is the perferred way
                      if you have your Mp3s organized by folder, Albumart art will use the 1st image it finds in the folder be it, cover.jpg or folder.jpg
                      if you want to use mp3 artwork that is embedded inside mp3s thats completly different and you need to install the the mp3art embedded artwork plugin
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Just to be clear: J is supported for compatibility only. The recommended way is using indicators as Mitch said. The problem with J is that it doesn't provide ways of using certain objects within the same screen (i.e. ALBUMART & COVERART) -- plus it assumes certain screens will always use the same type of art.
                        Ride Runner RR's Myspace
                          Hi Everyone,
                          I have solved the problem of unable to display album art in RR. It is because all my artists' folder name are not in English but Chinese, and I didn't change the "Language for non-Unicode programs" according to it. The album art shows after the fix even they are not named folder.jpg. I appreciate everone's help here. I hope this thread can serve as someone's tips in the future in similar situation. Thanks! =)
                          Jguy
                            john, now now
                            The following changes were made to the [RideRunner] code:
                            Author:
                            mitchjs
                            Log of Changes:
                            unicode folder names for ALBUMART
                            updated for unicode folder...needs to be completed for file read
                            Files Changed:
                            U _Plugins/Mp3Art/Mp3Art.vbp
                            U _Plugins/Mp3Art/RRExtension.cls
                            U _Plugins/Mp3Art/cMP3ID3v2.cls
                            A _Plugins/Mp3Art/cUnicodeFiles.cls
                            as I was saying??
                              if he had his non unicode applications settings correct
                              [ http://www.mp3car.com/vbulletin/rr-f...upport-rr.html ]
                              , he wouldnt have an issue
                              and this plugin isnt even in the picture here
                              but no one reads the FAQ, even I forgot all about this
                              and we hate to have it so "un-automatic"
                              but when someone says it "NO LONGER" works.... its how about It NEVER WORKED
                              cause of the the unicode...
                              but now in RR 5/1 it will
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
