Fresh Install of OS and RR - Problems
  • Fresh Install of OS and RR - Problems
    Hello,
    After fubaring my system I did a reformat of my drive and reinstalled XP and RR. All appeared to go well. I have now tried starting RR, however, and am running into trouble.
    Problem #1: Whenever I load RR regardless of skin my display color settings are automatically reset to low (8bit), making the display quality really poor. When using the Carwings skin when I exit out of RR the color settings automatically revert to Highest (32bit).
    Problem #2: Whenever I load RR using DFX the color settings are automatically reset to low (8bit) and then I get a black blank screen. I must then go to task manager to get out of RR. (When I close RR using taskmanager, the screen color setting does not automatically revert to high - I must manually reset it.)
    I have attached debug files for both Carwings and DFX. I have done plenty of installs of OS and RR and have never had this problem before. Relevant additional information is as follows:
    OS = Winxp SP3 (full)
    dot net is installed
    Current flash installed using IE
    DirectX 9 installed
    4/1/10 RR version
    Current display drivers installed
    Any help would be appreciated.
    Check your settings in RRConfig Page 2.
      Thanks, MGD. Yes, I am an idiot.
