I have a problem with OSKTOVAR
  • I have a problem with OSKTOVAR
    Can someone tell me why this doesn't work?
    Code:
    B30,3,110,75,36,"OSKTOVAR;RRGS_SEARCH1||OSKTOVAR;RRGS_SEARCH2||RRGS_GetDirections;$RRGS_SEARCH1$;$RRGS_SEARCH2$","Search"
    Both variables exist.
    What happens is that the first OSK appears but RR doesn't wait for ENTER instead it executes the rest of the commands with the second OSK not appearing.
    RRGS_GetDirections is a command processed by a plug-in I'm writing.
    Regards,
    Jim
    You need to use the "OSKTOCMD". More like this..
    "OSKTOCMD;RRGS_SEARCH1;RRGS_SEARCHCONT1"
    Then, your plugin process the "RRGS_SEARCHCONT1", which then issues the second "OSKTOCMD" instance like:
    "OSKTOCMD;RRGS_SEARCH2;RRGS_SEARCH2CONT"
    Then, from there you can process your "RRGS_GetDirections" cmd..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      What I would do instead is something like I did in the RREarth skin..
      Put a label "EXEC;OSKTOVAR;RRGS_SEARCH1||=$RRGS_SEARCH1$" and another one "EXEC;OSKTOVAR;RRGS_SEARCH2||=$RRGS_SEARCH2$" on the screen, this make them clickable and visible, so the user can edit the 1st var and/or 2nd var only when desired (allowing to change just what needs to be changed -- at the desired pace), then just have a "search" button with the code "RRGS_GetDirections;$RRGS_SEARCH1$;$RRGS_SEARC H2$" -- to just perform the search using the previously set parameters.
      Ride Runner RR's Myspace
        ah the power of riderunner... take that you other front ends
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          With such confusion comes great power, just like girder. Extremely, complex and confusing at first but once ya figure it out.....nothing can hold it back, only your imagination.
          DFX 5.1.1 Skin
          Appstore Link
          RRMedia
          RRExtended
          DFXVoice
            what ever you're on, cut the dose!
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              Sorry but drug free here, don't know bout your end though..
              DFX 5.1.1 Skin
              Appstore Link
              RRMedia
              RRExtended
              DFXVoice
                If only there were a size tag so people's signatures wouldn't be 10 times as long as their posts. :v
