minicam container for embedding
  • minicam container for embedding
    since there was no real and current solution I ended up writing a autoit container for 4 copies of minicam to allow them to be embedded on the same Riderunner skin screen I hope of others find it useful.
    to use simply add the cam.exe to your minicam folder and either embed it into a skin or simply run.
    http://neondawg.com/~Reg/cam.zip
    I hope everyone enjoys,
    yonu
    This is a very good idea.
    Is it possible to see your source code to see how you have done that ?
    Thanks ...
      sure when i get in this afternoon I will post it as it is on my home pc
        Thank you, it's very cool !
          here is the code it is fairly straight forward it will work to embed any program
          Code:
          #include <GUIconstantsEx.au3>
          #include <WindowsConstants.au3>
          #include <WinAPI.au3>
          $hGui = GUICreate('cams', 800, 508, 100, 100, BitOR($WS_POPUP, $WS_SIZEBOX, $GUI_SS_DEFAULT_GUI, $WS_CLIPCHILDREN))
          GUISetState()
          ; Open minicam
          Run("minicam.exe")
          WinWaitActive("CuriousTech - MiniCam 1")
          ; Resize MINICAM to fit
          $hminicam = WinGetHandle("CuriousTech - MiniCam 1")
          WinMove($hminicam, "", 0, 0, 400, 254)
          Sleep(0)
          ; Open minicam
          Run("minicam.exe")
          WinWaitActive("CuriousTech - MiniCam 2")
          $hminicam1 = WinGetHandle("CuriousTech - MiniCam 2")
          WinMove($hminicam1, "", 0, 255, 400, 254)
          Sleep(0)
          ; Open minicam
          Run("minicam.exe")
          WinWaitActive("CuriousTech - MiniCam 3")
          $hminicam2 = WinGetHandle("CuriousTech - MiniCam 3")
          WinMove($hminicam2, "", 400, 0, 400, 254)
          Sleep(0)
          ; Open minicam
          Run("minicam.exe")
          WinWaitActive("CuriousTech - MiniCam 4")
          $hminicam3 = WinGetHandle("CuriousTech - MiniCam 4")
          WinMove($hminicam3, "", 400, 255, 400, 254)
          Sleep(0)
          ; Set minicam as child of our GUI
          $hOriginalParent = _WinAPI_SetParent($hminicam, $hGUI)
          $hOriginalParent1 = _WinAPI_SetParent($hminicam1, $hGUI)
          $hOriginalParent3 = _WinAPI_SetParent($hminicam2, $hGUI)
          $hOriginalParent4 = _WinAPI_SetParent($hminicam3, $hGUI)
          While 1
              Switch GUIGetMsg()
                  Case $GUI_EVENT_CLOSE
                      ;Reset minicam to original parent
                      _WinAPI_SetParent($hminicam, $hOriginalParent)
                      Sleep(500)
                      WinClose($hminicam)
                      Exit
              EndSwitch
          WEnd
          Enjoy,
          yonu
            Looks good.
            I made one small change to MiniCam so you can hit the borderless button and it doesn't reposition. Don't use fullscreen mode though.
            http://www.curioustech.net/minicam.html
              cool thanks and thank you for the not fullscreening warning as I haven't tried fullscreen yeat. just figured it would work
              figures as I had planed on being able to fullscreen lol but hey i can live without it
              yonu
                Well, download it again. I made it do fullscreen, but there's no overlay buttons and you have to double-tap.
                  thanks yonu
                    cool thanks Curiosity
                      yonu,
                      Nice, simple piece of work, well done.
                      Have you updated the source you posted when you included full-screen support?
                      Were did you download minicam from?
                      And what cameras does it support?
                      Regards,
                      Jim
                        well minicam can be downloaded from http://curioustech.home.insightbb.com/xport.html which is Curiosity's site as they designed minicam and nope i haven't updated the source code as the changes were made to minicam not the container I posted and as far as I know minicam will work with any WDM camera
                          yonu,
                          Thanks for the info. I've downloaded minicaml and I am in the process of playing with it natively with one camera and already have a couple of questions:
                          1. Once in full-screen, how does one get back to the small image?
                          2. where does minicam store its settings?
                          Once I've played with it a bit, I'll give it the acid test. A four camera setup using 4 of the same cameras that no other package seems to be able to run successfully all at the same time. I can get 2 and sometimes 3 on a good day. I've tried at least 4 different packages, in 3 cases I tried multiple instances of a single app and the 4th proported to support all four at the same time. Interestingly, all of the cameras work fine if I only use then one at a time.
                          So I ended up writing an AutoIt app that displayed each of the cameras in a rotation where I dynamically changed the active camera in the program. I used AmCap for the camera support.
                          Therefore, I am quite interested to see if minicam will do as I want (4 at once) with my cameras (4 $16.95 el cheapos).
                          Regards,
                          Jim
                            what is the verdict on 4 cams at once the nost i have tryed is 2 so far as I am still deciding on the locations of the last 2 cams
                              Maybe you should write a 2 cam version.
                              @obrienj Fullscreen toggle is either double click anywhere or ESC key.
