RR 07-01-2010 Release
  • RR 07-01-2010 Release
    July 2010 Release ... its summer alright, anyone actually watching that soccer stuff?
    Download Here
    Mostly little tweaks, a minor bug or two... maybe a new feature or two.
    some highlights:
    • Synced internal Audio & Video File types to User Variables
    • User Var; "mediatypeinserted", for "ONMEDIAINSERT" event, 0 = Unknown, 1 = DVD, 2 = Audio CD
    • Indicator; "VISU", true is visualization is running
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    06/30/10
    * Improved parsing of exectbl.ini
    06/24/10
    * Improved winamp data file location, now gets it from winamp's path.ini file if present
    06/22/10
    + Improved "visuname" processing
    + Added "++" as option for the SETLABELCODEID cmd to support setting multi labels on a single label
    06/17/10
    # fixed TV mode use of winamp, and loading in .tvc channel files into playlist
    06/14/10
    + All Audio players now properally use setting "audiofiles", when loading folders
    + All Audio players expose method IsVisuOn()
    * Extension Plug-ins, Unload Method is now Terminate, to not confuse with VB6 Global form UNLOAD
    # Pseudo fix for winamp bug, when winamp in pause, and and forwarded past actual total track time
    + Indicator; "VISU", true is visualization is running
    06/05/10
    # Synced internal Audio & Video File types to User Variables
    + User Var; "mediatypeinserted", for "ONMEDIAINSERT" event, 0 = Unknown, 1 = DVD, 2 = Audio CD
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Cool, I try it immediately !
      I keep getting "The setup files are corrupted. Please obtaing a new copy of the program." error when I download and try to install.
      This is with both the run and save options when downloading. Is it just me?
      Thanks.
      CAR: 2007 G35 Sport Coupe 5AT
      HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
        ^downloaded and installed fine for me
        03 Hyundai Elantra GT {Worklog}
        HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
        RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
        cmdRR tall skin creator
        86 Pontiac Fiero SE 2m6
        possible carpc install
          Yes it installed fine on my second laptop.
            Thanks.
            Could be an anti-virus thing blocking access or something ?
            Ride Runner RR's Myspace
              I ended up downloading on a different computer and installing from a flash drive and it worked just fine. Something must have corrupted on the download. Thanks.
                installed and ran great!
                so far it looks awesome, thanks.
                I'm having some trouble with XM but I'm sure I just need to play around with the settings. I'm upgrading from a Road Runner version released 2 years ago lol
                EDIT: XM works perfectly!
                Mercedes Benz CLK 430
                  Still rock-solid. Thanks.
                  OLD SYSTEM (DEAD)
                  Intel D945GCLF2 Dual Core ATOM
                  Lilliput 7" 629GL 2008 LED Backlight
                  BU-353 USB GPS Receiver / iGuidance / IGO8
                  M2-ATX Power Supply
                  RideRunner Front End / Various Skins
                  Windows XP SP3
                    Question with the visu indicator.
                    I'm trying to use it but it's not doing as I'm wanting.
                    I've got this in the exectbl.ini
                    "cmdRRvis","BYIND;VISU;<<VISU;"
                    and this as a button in the audio_player.skin
                    B,200,249,100,76,"cmdRRvis||LOAD;menu.skin"
                    But if I turn on visualization in the audio screen and then try to go to the menu, the visu is still running, and is still there when I come back to the audio player... though I have to click on the visu area to make it pop to the top. I thought it would have checked if it was on and then run the visu command and turned it off before switching screens.
                    Do I have it coded wrong? or is it just not working right?
                      sargeants, hu?
                      extra semicolon dont help
                      "BYIND;VISU;<<VISU"
                      if on, turn off
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        i reformatted yesterday and reinstalled a fresh copy of rr and dfx4. holy crap do things work better now... i mean holy crap its awesome that things actually work now....
                          Thanks Mitch - knew it had to be something simple that I was messing up.
                          yea that's what I'm wanting - if on turn off
                            I hope this is the place to write this: i have problems now with AVS not embedding into RR
                            Everything was fine 2 days ago, running winamp 2.95 and RR march - version.. Now updated RR to 7-1-2010 and the AVS is not embedding, it just keeps showing in a separate window on top what could be the trouble? i already try to configure it with RR Config, and after that i checked rr.ini and appears visuname=!Winamp Gen!AVS.. i'm not trying to make it transparent, just to embedd into a Axx,xx,xx area..
                            Thanks for the help! keep the good work!
                              i know that im embedding it currently into Carwings.. on the audio_player.skin
                              my difference im using a much much newer winamp 5.572 (or something like that)
                              remember with the A skin definition, you would have to TURN on VISU for it to embedd, if visu is already on, when you load a skin with a A definition, it wont embedd... unless that was the skin it was initially embedded on... if that all make sense...
                              but.. hint hint... look at carwings skin for audio_player.skin
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
