About to Give Up with HDRadio
  • About to Give Up with HDRadio
    I had a hard drive failure and reinstalled windows in a new drive along with RideRunner, etc. But know can not get HDRadio to work after new/fresh install.
    Here are the Specs:
    Windows 7 Professional 32 bits.
    RideRunner latest version 07-01-2010
    Radio: HDRadio Visteon HD-Zoom
    Cable: Mitch Serial Adapter
    Port: Built-in Com1 and also tested USB2Serial
    I can get the radio to work with Mitch radio app outside RR without a problem. But in RR I get the following error:
    Radio Support
    Radio not Configured
    Please run RRConfig and select the Radio you wish to use.
    I have tested with MoBo built in Serial port in Com 1 and it doesn't work on RR, however with Mitch ext app works fine.
    Also have tested with a USB2Serial and it does work with Mitch ext app but still no joy in RR.
    I have tried 3 different skins:
    DFX 4.0
    Reborn
    RR built-in Carwings Lite
    Neither one works, so the problem its coming from RR itself.
    I checked the RadioModules folder and it does have the HDRadio subfolder with the proper files:
    HDRadioComm.dll
    HDRadioRR.dll
    HDRadioRR.tlb
    MJSGAudio.dll
    Here's the rr.ini radio section:
    [Radio]
    radio=HDRadio
    allowallfreqs=true
    uselineinplugin=false
    lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
    uselineinsingleinstance=false
    userbds=false
    RadioPort=7
    HDRadioType=Directed
    Please help. Thank you.
    Mike K.
    change RadioPort=7 to RadioPort=1, assuming you've put it back to com 1
      Also you need to make sure the radio .dll is registered. Go into this folder:
      \RideRunner\Plugins\MJS Gadgets\HDRadio\
      and double click "runme1st.cmd ".
      My Fiero Build Thread
        john, there is nothing like that
        hd radio isnt a plugin
        its a radio module...
        there is no runme1st.cmd...
        that was like 2 years ago
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          Not the case I have used Radioport=1 when testing the HDradio with the built in Com1 and Radioport=7 when testing the HDradio with USB2Serial.
          Thank you anyway.
            and so, do u have it working yet?
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              John, as always your input so crucial pointing to the right direction.
              Mitch, that's exactly the problem. I believe you have a regression in the RideRunner installer sometime between the versions February 2010 and June 2010.
              I unistalled RR version July 2010 and installed June 2010 and always with the same bad result.
              However I noticed that either version (June or July 2010) only creates ONE HDRadio folder in the entire RideRunner install, that folder contains the files that I specified on my first post:
              HDRadioComm.dll
              HDRadioRR.dll
              HDRadioRR.tlb
              MJSGAudio.dll
              I did noticed that on both last installer versions (June & July) RideRunner installer before finishing it tries to register SiriusRadio, XMradio and HDradio. However after all install completes when I check the MJS Gadgets folder there's only the 2 following folders:
              SiriusRadio
              XMradio
              So basically the required HDRadio folder does not get created with the required .dll files under MJS Gadgets.
              What I did then was to clean out one more time, uninstalled again RideRunner and I tried a installer that I had working before hard drive broke. The installer is February 2010.
              After the install completed, I have now under the MJS Gadgets folder the 3 radios:
              HDradio
              SiriusRadio
              XMradio
              Checking the files inside under MJS Gadgets\HDRadio I have the files that John pointed out:
              HDRadioComm.dll
              HDRadioComm.tlb
              RegAsm.exe
              runme1st.cmd
              UnRegMe.cmd
              Also inside of the folder RadioModules\HDRadio i have only 1 file (not those 4 previously reported):
              HDRadioRR.dll
              With this installer from February 2010 my HDRadio works perfect.
              I believe that anyone doing a fresh install will run into the same problem as I did.
              I also believe that this was not noticed because once you do an upgrade from previous working version (like February 2010) to June or July 2010 it will still work because missing files still there and .dll still properly registered under Windows.
              Mike K.
                all that mjsgadets/hdradio is OLD OLD OLD OLD!!
                NONE OF THAT IS USED ANYMORE
                and NOT FOR MONTHS!!..
                all the newest installers, all have a clearn up code...
                but if you want, be smart, and do a UNINSTALL OF RIDERUNNER,
                then REINSTALL RIDERUNNER with 7/1/2010 installer
                these are the ONLY files used
                RideRunner/RadioModules/HDRadio/
                HDRadioComm.dll
                HDRadioRR.dll
                HDRadioRR.tlb
                MJSGAudio.dll
                if you mess with the old ones, ie try to reg them, HD Radio will not work
                UNINSTALL RideRunner, reinstall RideRunner (7/1/2010)
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  mate the radios are modular..you will find all radio folders inside a folder called "RadioModules" in your RR path (program files...etc)
                    HDRadioComm.dll
                    HDRadioRR.dll
                    HDRadioRR.tlb
                    MJSGAudio.dll
                    Mitch, sorry but I believe I did not explain well or something. As I mentioned on my previous post I did:
                    uninstall July 2010 completely making sure all was clean and installed it gain. NO GOOD.
                    Then
                    Unistalled July 2010 and cleaned up all and installed June 2010 - STILL NO GOOD.
                    Then
                    Uninstalled June 2010 and cleaned up all and installed February 2010. THIS ONE WORKS.
                    Then
                    Installed/Upgraded July 2010 "ON TOP" of February 2010 good working install and still works fine after July 2010 upgrade as expected/commented on my previous post.
                    Believe me, I'm not pointing anything out to you or saying anything bad about your installer. I just like to say that IMHO there's a problem with the new installer that came sometime after February 2010. That Only can be noticed if you PERFORM A FRESH INSTALL.
                      i dont think so... i just did a fresh and its fine...
                      so lets not get creative here, just do what i ask, and we debug/solve from there
                      install JULY 2010... Selecting HD Radio from the optional radio's list
                      at this point... when install complete, there should be NO hd radio directory inside mjs gadgets, and just a hdradio directory in the radio modules directory
                      now, RR.ini
                      Radio=HDRadio
                      Radioport=x x= comport
                      now since you prob used older versions of RR CONFIG (take a look at the bottom of the rr.ini file for duplicates!!!!!)
                      not to mention HDRadioPort which is obsolete
                      since u didnt attach a rr.ini, i cant check it
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        i did a fresh install too latest ver...it works OK
                          just OK, you mean it works GREAT!
                          we do better than OK here
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            It's working good now they way I did with Feb 2010 then July. I believe you guys are absolutely correct and GREAT!!!
                            I'm not just in a mood to uninstall and re-install. I won't be surprised that it something weird on my Windows 7 install.
                            Thank you all, again you're great...
                              no its not windows 7...
                              uninstalling, reinstalling does NO harm, no user data is changed
                              uninstall will clean up your directory...
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
