ride runner questions
  • ride runner questions
    I setup my ride runner system this week end.
    my question is
    1) I am running iguidance 3.0 and when i goto gps screen it goes full screen and i do not see the ride runner screen around it. what changes do i need to make to make this work?
    and
    2) when i play video it has a major blue tint to it. I have tried to use the gamma control panel
    and make adjustments in vlc player to no avail any ideas on how to correct this?
    3) can I have multiple webcam and select between them?
    thnks in advance for any help that is rendered
    system specs
    microxt motherboard 733mhz in a video on ip settop box
    512k ram
    tiny windows xp
    15 gig sd card (thru ide to sd adapter)
    radioshark am/fm (working on modifiying to connect to car antenna)
    logitech webcam
    rand mcnally serial gps reciever
    7 in screen (ripped from a non-working protable dvd player)
    my question is
    and
    system specs
    512k ram
    tiny windows xp
    logitech webcam
    What skin are you using?
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
      sorry
      I knew i should have added that
      carwings_dynamic_lite
      un-modified as of yet
      I will be moving around some of the buttons once I get everything running right
        WHAT ARE your gps nav settings...
        assuming you use rrconfig
        gps mode = external, ig native checked, GPS path is set to ig's exe
        and GPS window name is iGuidance
        rr.ini:
        gpsmode=2
        gpspath=C:\Program Files (x86)\iNav\iGuidance\iGuidanceUMPC.exe
        gpsname=iGuidance
        optional ig native stuff:
        [IG Native]
        ignative=true
        igautosw=true
        gpsonvoice=true
        pauseonvoice=false
        lastscreenswitchtime=0
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          video
          the video plays fine in vlc player outside of RR
          I will need to recheck my settings on the carpc as far as iguidance is concerened
          but i do not believe i put in the window name in rrconfig
          I will check when i get ready to leave work to day
            iGuidance
            that took car of my iGuidance problem
            thanks a bunch for the help
            now if I could just get the people to stop looking like avatars when I play video
            and while I am at it
            What webcam do you find works best with road runner
            (the one I am using does not work well in day or night driving but works wonderfully at dusk)
              try another video player... like builtin
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Blue Tinted Video
                it make no difference what video player I use
                I get the blue tint inside of road runner but I do not get it outside of road runner
                I like vlc player as it supports more video codecs and on a 733 mhz system does not drag the video
                I have looked at taking the background screen out (it is the default blue smoke) but it had no effect on playback
                  i cant tell you what it is then...
                  use carwings
                  use built in video
                  use A DIFFERENT video!!!
                  vlc is all software based codecs, so if your mb has hw acceleration, not a good choice
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
