Can I stretch eLite Wings to 1024x768 easily?
  • Can I stretch eLite Wings to 1024x768 easily?
    I'm lovin the skin as it is, with a few tweaks. But I just got Garmin Mobile PC and the bar at the top of the Garmin display takes up too much of the screen.
    If I go to 1024x768 the bar gets a little smaller.
    Can RR stretch the skin or would I have to recreate all the images and button placements to match the higher resolution?
    Thanks,
    davidk
    You can change the resolution of the skin in the general.ini of the skin. As to the look your, mileage may vary.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
      You can change the resolution of the skin in the general.ini of the skin. You could also put the Garmin window to be negative in your GPS skin so it the top bar disappears.
        Thanks, I'll look at the general.ini.
        Is that different from the setting in RRconfig Genera|Page2 "Run RR at this resolution"?
        What do you mean "put Garmin window to be negative"? I'd love to get rid of the Garmin window top bar.
        Thanks,
        davidk
          If you open the externalgps.skin file, you will see a line that starts with an A. (It is probably the external.gps skin in your skin file folder.)
          In the A line it will look something like A,0,-5,800,520,"iGuidance"
          The A is the line type, I believe that it is application in this instance.
          The 0,-5,800,520 is the x and y axis of the start of the iGuidance window and the width 800 and height 520 of the window.
          If you were to make the -5 more negative, the iGuidance, or in your case the Garmin window move more to the top of the screen, making the Garmin top bar disappear.
          You can also do this in the skin editor which should be in your RR install folder.
            Got it!
            Using skin editor, the "A" object? that defines where to put the garmin window.
            The Y coordinate should be a negative number which will push the window up beyond the edge of the screen.
            That fixes everything I was having issue with tonight. It's displaying as much map as possible at 800x600. I'm going to test it out, but I think I'll be happy at this resolution for now.
            One last thing to figure out is how to get Que.exe to close when exiting RR.
            I know I saw some posts about this so it's search time again.
            Thanks for the info.
            davidk
              Don't know if Elite has it but, in DFX 4 there is a .exe called killtask.exe in the scripts folder. You can tell it what program to kill and have it run when you hit the exit button of your skin.
              There is also a taskkill.exe in the windows system 32 folder that you could use.
                eLite Wings.
                I really like the simple layout of it. I really only want to play music and gps right now.
                I've added a few buttons to the audio player already. Play previous artist, next artist and play selected.
                I had a VW with a PHAT Box that would play an artist, genre or album completely then automatically play the next. I don't know how to make it play the next automatically but what I've got working so far comes close.
                Thanks for the tip on killtask. I'll so some more searching.
                Thanks,
                davidk
                  i tried this last night and it works really well. thanks for the tip!! i only made a small adjustment but you can get the idea. in the "garmin" settings file in elite wings skin my settings are now:
                  A,0,58,800,485,
