What Player do you use with Ride Runner?
  • What Player do you use with Ride Runner?
    So.. we just wondering
    83
    Winamp
    77.11%
    64
    Foobar
    8.43%
    7
    Windows Media Player
    13.25%
    11
    iTunes
    1.20%
    1
    Fmod
    0.00%
    0
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Winamp, but I'd like to use Foobar. I find Foobar2k sounds just that little bit better but the last time I tried it there were some bugs when using it in RR (progress bar was jumping from 0 to actual time and back) plus there's no line-in function so I'd have to find another way to get radio to work.
      i know BASSRR is not an official player, but is the one i use
      BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
      RRTube ==> [View/Download Youtube Videos]
      WifiMan ==> [Wifi Manager]
      RRec ==> [Audio Capture]
      If You Want To Be Given Everything, Give Everything Up ...
      Bird York -- In The Deep --
        winamp and the reason is the Visu's
          because , it has the quality , runs most visuals, like winamp vis's, flexiable, and without all the stuff you never use, making it very light player.
          Riderunner / Genesis
          Wifiman_NET:Version 1.0.0
            Winamp because its always been there, great vis, supports shoutcast streams, and has myorb plugin so I can access my home cable channels, and all my movies, music, and pics on my home severs.
              winamp, though it wold sure be nice if the song data wasn't just limited to id3 tags in rr (it bothers me that winamp sees the correct full info, but rr doesn't..)
              next project? subaru brz
              carpc undecided
                I've never tried winamp...is it just for music, or for movies too?
                Linux(Learning the curve...Like when driving!!!)
                Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
                  hu?
                  i bet you dont have it set to the format you want!
                  tell winamp to handle the meta data on load (so we have it avail)
                  and define your format...
                  in the section below
                  read the ATF help if needs be...
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    hmm, so the meta data is read by rr--(is this the "other formatting" part in rrconfig? i have not changed it from its default)?
                    i checked winamp, and it was set on the second option down(to read the metadata as the file was playing), and the display format was setup exactly the same as your screen shot.
                    i am still having issues...
                    carpc undecided
                      if the second option is set, RR is providing the tags NOT winamp!
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Winamp has worked flawless since day 1.
                          Internet Radio Info - Not Showing Up
                          Originally posted by mitchjs View Post
                          hu?
                          Mitch,
                          I am having this same problem as well (never has worked). I have used the settings you mentioned above in WinAmp to show the internet radio info (only see the address info - http://xxxxx)but can't get it to work. Any other settings to check in Winamp or RR?
                          RR Oct. Release
                          DFX 5 Skin
                          WinAmp 5.572
                          WinXP Pro
                          I can attach a debug file if needed.
                          Gee
                            "official" hmm, a player is a player.. if it works then whats the issue?
                            Blessed are the "cracked" for it is they who let in the light.
