NIGHTSKIN command doesn't override Auto time switching
  • NIGHTSKIN command doesn't override Auto time switching
    I have Auto skin change toggled on in RR Config and it works fine. I created a button to manually select day or night skins, but after a second it switches back. Same thing happens when I use skin browser. How do I give the auto switcher a lower priority so my manual selections stick?
    Code:
    B,595,117,165,116,"fusion_vote_DashLT1||DAYSKIN",
    L3,1025,0,5,5,255,255,255,12,#DFXFont#,"=.",
    B02,596,233,170,113,"fusion_vote_DashLT2||NIGHTSKIN",
    B04,593,350,173,117,"fusion_vote_DashNFS",
    I'm running the 8/5/2010 version of RR and my skin is a modified version of Carwings.
    off the top of my head, i dont think you can
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Code:
      Shouldn't that be #fusion_vote_DashLT1Font#?
      My Fiero Build Thread
        I was thinking on this a little bit more....
        Mitch, is the auto day/night skin switching set to work on the fly, meaning changeable at run time?
        If it is, it could be fairly easy to set up. When you change day/night manually, Have code on the same button to turn the auto switching off. Then, at OnSkinStart always set the option for it to be on.
        What this would do, is when you change it manually, it would not auto switch again, and would stay with what you have it set. Then when RR restarts, it would default back to auto switching again.
          john, im sure... we can keep coding and coding...
          i havent looked at day/night skin switch in along long long time
          if someone wants this feature, they know where to request it
          oh as for on the fly, i dont know
          i dont even know what controls this
          if its
          "autoskinmode"
          no, not changeable on the fly
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            AutoSkinMode is now a uservar
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              Well that should take care of it then. Anyone can just put a button in their skin to turn the auto switching on and off.
                Maybe? But it works the way I have it. Changes the skin on my second monitor running Fusion Brain MDX.
                What took so long?
                Thank You.
                  Actually, from what I recall AutoSkinMode = 0 is Auto, AutoSkinMode = 1 is 3 State Control , and AutoSkinMode = 2 is Off. If you use it =1 then you can execute "daynightskin" and it will switch between Day/Night/Auto.. so I don't understand why have the setting changeble in runtime other than to be able to configure it from the skin (which is always nice).
                  Ride Runner RR's Myspace
                    see, someone here actually knows how to use RR
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      The AutoSkinMode works well. RR went back to auto when restarted like I wanted.
                      Appreciate the help. Now on to the next dumb question...
