RR 10-04-2010 Release
  • RR 10-04-2010 Release
    ITS OCTOBER!!! where did summer go???
    UPDATED:
    features just for DFX5 to 10/1/2010 Release
    Download Here
    we got a bunch of new stuff in this release
    some little bugs fixed.. (lot I found myself)
    Highlights:
    • Skin Command; "RELOADALLSCREENS", unloads all screens, and reloads all of the screen that where loaded
    • Skin Command; "IFVAR" simple variable compare (equals or not equals only)
    • GLOBAL Hot key support
    • Indicators now support "byvar"
    • Plugin Manager plugin disable at start persistence
    • Skin Command; "UNLOADALLSCREENS", will unload all screens except current screen and menu
    • Winamp media library database support (used proper method to locate it)
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    10/3/2010
    + Skincommand; "IFVAR" simple variable compare (equals or not equals only)
    	ex. "IFVAR;myvar=5;DOTRUE<<DOFALSE"
    			if myvar = 5 then "DOTRUE" would execute, else "DOFALSE"
    	ex. "IFVAR;ACTIVESOURCEID<>1;LOWERANT<<RAISEANT"
    			if activesourceid <> 1(hd radio) then "LOWERANT" else "RAISEANT"
    10/2/2010
    * Skincommand; "UNLOADALLSCREENS", now unloads ALL screens, and reloads menu.skin and current screen
    	Note: "skin.ini", "general.ini" will be processed (on the menu.skin load)
    + Skincommand; "RELOADALLSCREENS", unloads all screens, and reloads all of the screen that where loaded
    # HDRadio/venice5/venice7 list position updating on "menu.skin"
    9/29/2010
    * Plugin Manager command format, ; now replaces |  (| is still supported, but depreciated)
      ex. "pluginmgr;enable;xxx" - enables plugin named "xxx"
    + Plugin Manager plugin disable at start persistence (see Plugin Manager.txt)
    	ex. "pluginmgr;enable;xxx;save" - enables plugin named "xxx" and removes plugin from disable list
    	ex. "pluginmgr;disable;xxx;save" - disables plugin named "xxx" and adds plugin to disable list
    9/25/2010
    + GLOBAL Hot key support in KeyTBL.ini
      example: *2112,"SkinTool"
      (NOTE the Asterix)
      this would be a global CTRL-F1
      (Do not make all your keys global, it may cause conflicts with other programs, and be annoying)
      (All keys are attempted to register are noted in debug.txt, including failures (reserved by other programs or Windows)
    9/21/2010
    + Indicators now support "byvar"
    	ex. I,xxx,yyy,hhh,www,"byvar;myuservar;image0.png<<image1.png<<image2.png"
    	 when myuservar is 1 or true, and will show image2.png when myuservar is 2]
    	ex. I,xxx,yyy,hhh,www,"byvar;myuservar;false<<true"
    	[Will show off layer image, when myuservar is false, and will show on layer image
    	 when my uservar is true]
    	real ex. I,400,10,32,32,"byvar;daynightskinmode;$skinpath$sun.png<<$skinpath$moon.png<<$skinpath$clock.png"
    ^ Cleaned up code around "daynightskin" command
    * UserVar; "AutoSkinMode" setting is now a user variable. (ie change be changed on the fly)
    + UserVar; "daynightskinmode" is now a user variable. It controls how skin will change
      (overriding "AutoSkinMode"). "daynightskinmode" = (0 - day, 1 - night, 2 - auto)
    	This functionality is is enabled when setting "autoskinmode" is 1,
    	"autoskinmode" is (0 - auto, 1 - auto w/daynightskinmode, 2 - disabled)
    9/20/2010
    ^ Carwings_Dynamic_Lite small updates and cleanup
    9/18/2010
    # Adding a song from within a m3u if only 1 song is inside the m3u (rare)
    # FoobarRR.dll Running status is now correct, so PlaylistPosition and TrackPosition is preserved on close of foorbar.exe
    9/17/2010
    # Winamp media library database support (used proper method to locate it)
    9/16/2010
    * How screen resolution is determined
    * Indicator image aspect ratio calculations improved
    9/15/2010
    # Fixed single item in playlist tag issue
    # Added to to .m3u browse if no full path on song is present, attempt to rebuild path will happen
    9/12/2010
    # COM Receive (WM_COPYDATA) of messages if they ended in chr(0)
    9/3/2010
    # Drop Shadow text effect colors
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    I know I requested, so I therefore apologise for not getting back to you with any testing on it since you added it.
    For some reason I cannot access your FTP from home, but can at work (guess I have set my home firewall stricter than work has their ), and by the time I was back at work I had done all my testng with my skins and released them without making use as I was going to.
    Hopefully will test soon to see ifit's what I needed.
      Thank's for adding disable plugins at start option.
        Cool !
          Lovely, thanks.
            Cool IFVAR command .
              Can you say me if the option 'Reduce Sound Volume to:' run with all GPS software as Sygic or GMPC or it is just for IG4 ?
                Highlights:
                Code:
                LEGEND:
                - = Removed
                + = Added
                * = Changed
                # = Bug fix
                ^ = Note
                10/2/2010
                Hang on, these are now two different things.
                The whole idea of the unloadallscreens was not to unload the current screen or the menu screen so that the skin.ini and general.ini didn't get processed again.
                Otherwise it's the same as reloadskin isn't it?
                  Any gps sw that modifies the wave line when speaking
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
                    That this is probably the dumbest question around here, but how can I send a command to RR from an external software?
                    For example,
                    run "load;load;Audio_Player.skin" from a x.bat file.
                    Is there a way to do something like the send command of the skinner tool? Is the EXEC.exe file in rr folder somehow related to that question?
                    Thks in advanced!
                    Engineering: Where the rubber meets the road!
                    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
                      Nevermind, I already figured out: Exec.exe load;Audio_Player.skin
                        UPDATED:
                        Download Here
                        Highlights:
                        [LIST][*]Skin Command; "RELOADALLSCREENS", unloads all screens, and reloads all of the screen that where loaded[*]Skin Command; "IFVAR" simple variable compare (equals or not equals only)[*]GLOBAL Hot key support[*]Indicators now support "byvar"[*]Plugin Manager plugin disable at start persistence[*]Skin Command; "UNLOADALLSCREENS", will unload all screens except current screen and menu[*]Winamp media library database support (used proper method to locate it)
                        [/CODE]
                        Mitch, when you say "GLOBAL Hot key support" does it mean that Hot Keys will work even if RideRunner is not the current active window ?
                          To what extent is the Winamp media library database support? I didn't see any real mention of it in the the documentation. Has the internal search been updated as well?
                            UNLOADALLSCREENS is NOT like reloadskin...
                            its close, but not the same...
                            since i never knew the point of "unloadallscreens" from you
                            its HOW i interpreted it.. and it can go either way
                            but when working one on one with john, i learned how to actually unload al lscreens
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              ah yea... that what global hot keys are
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
