RR 11-01-2010 Release
  • RR 11-01-2010 Release
    holy BEEP its november already!
    Download Here
    We got a few new things, some eye candy...
    only 1 bug fix (thats good)
    Highlights:
    • New Transition Effects - (see New Transitions.txt)
    • Plugin Manager - added settings and about support for plugins
    • Plugin SDK additions - SetVar, GetVar
    • Setting - "STARTUPVOLUME=" At startup, this sets the master volume
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    10/27/2010
    * Improved Full Pre-load of screens
    + Extra Transitions (11 - 26) (see NEW Transitions.txt)
    + Setting; "randomeffectlist=0,1,2[,N]" - Random Effect List Setting
    	When transtiion=10 (Random) this defines the list of transitions to choose from randomly.
    	(see settings.txt for more details)
    # Fixed DefaultBG setting issue
    + Venice7M Text window color option (see Venice7 (Master) Radio Module.txt)
    10/23/2010
    + Skincommand; Events can now have * as 1st character when generated in a plugin, and the
      plugin coder wants the event to be public, IE seen by other plugins directly
      ex.  "*ONMYCOOLPLUGIN_HOTSPOTDETECTED" - (this will pass into all plugins, EVEN if translated in exectbl)
      ex.  "ONMYCOOLPLUGIN_HOTSPOTDETECTED"  - (this will not pass, to other plugins)
    + SDK; SetUserVar method, same as "SETVAR;uservariable;newvalue", but instantaneous, not queued by engine
           and simpler to use.
      ex. SDK.SetUserVar("myvar","10") vs SDK.Exec("setvar;myvar;10")
    + SDK; GetUserVar method, alternative method to SDK.GetInfo("=$myvar$")
      ex. string var = SDK.GetUserVar("myvar")
    10/20/2010
    + Plugin Properties now supports "author" property
    	Label: "pluginmgr;author;xxx" 			- returns plugin's author information for given plugin name "xxx"
    + Plugin Manager settings command
    	"pluginmgr;settings;xxx" - calls method "Settings" in  plugin named "xxx"
       if method not present an attempt to load skin "<pluginname>_settings.skin" well be made
       if method is present its the skin load is not attempted (you can always load one from inside plugin)
    + Plugin SDK Settings Method
    + Plugin Manager about command
    	"pluginmgr;about;xxx" - calls method "About" in  plugin named "xxx"
       if method not present an attempt to load skin "<pluginname>_about.skin" well be made
    10/16/2010
    * Updated SkinEditor to version .76g (see history.txt in skineditor folder for change list)
    10/11/2010
    + Setting; "STARTUPVOLUME=" At startup, this sets the master volume to 0 - 100 % or
    					 use -1 = for dont touch master volume at start (or setting not present)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    they were in 10/4 release, course UnloadScreen slightly changed, but dont remember what day, 11th
    10/2/2010
    * Skincommand; "UNLOADALLSCREENS", now unloads ALL screens, Except menu.skin and current screen
    + Skincommand; "RELOADALLSCREENS", unloads all screens, and reloads all of the screen that where loaded
    Note: "skin.ini", "general.ini" will be processed (on the menu.skin load)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
      The download link is up now...
      Ride Runner RR's Myspace
        nice, very nice, thanks a lot for the new addition. i really like this * event, now i need to update my PI's.
        BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
        RRTube ==> [View/Download Youtube Videos]
        WifiMan ==> [Wifi Manager]
        RRec ==> [Audio Capture]
        If You Want To Be Given Everything, Give Everything Up ...
        Bird York -- In The Deep --
          Cool, thanks for this new update !
            Just a question please?
            What is the raison to add the option setvar et getvar into the sdk ?
            SDK.Exec("setvar;myvar;10") was not suffisant ?
              I try to use the new sdk option .
              So, i have just added into the RRSDK.cls file:
              Code:
              Public Sub SetUserVar(UserVar As String, Value As String)
                  If PluginEnabled = False Then Exit Sub
                  RRSDK.SetUserVar UserVar, Value
              End Sub
              Public Function GetUserVar(UserVar As String) As String
                  If PluginEnabled = False Then Exit Function
                  GetUserVar = RRSDK.GetUserVar(UserVar)
              End Function
              I want to replace:
              RRSDK.Execute ("SETVAR;GPXLATNEW1;||SETVAR;GPXLONNEW1;||SETVAR;G PXINFO;***")
              by
              RRSDK.SetUserVar ("GPXLATNEW1",""||"GPXLONNEW1",""||"GPXINFO","***" )
              It's the good way ?
              I have tried only that with a syntax error !
              RRSDK.SetUserVar ("GPXLATNEW1","10")
                Soon as i release an example plugin you guys change the SDK lol
                Live mp3Car Facebook Chat
                  pierrotm777,
                  no || in the strings... its just a function that sets a variable immediatly
                  not run though the execution engine
                  RRSDK.SetUserVar("myvar","100")
                  sets "myvar" to 100
                  also look at the plugin examples installed with the installer, i updated
                  them all the sdk class)
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    no changes, per say, only Additions!!
                    i wanted instant vars, vs exec engine processed
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      yea, i been wanted this for a long long time....
                      its been on my list of things to do for months
                      i just started writing a new plugin for a new product im going to be offering
                      and figured ill just code it up now
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        speaking of neat things... try the carwings_dynamic skin, and on menu2, click on the dimmer
                        and watch how that popup works
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          Originally posted by mitchjs View Post
                          pierrotm777,
                          sets "myvar" to 100
                          mitchjs,
                          I try again directly into the plugin example :
                          Code:
                          Public Sub Initialize(pluginDataPath As String)
                              On Error Resume Next
                              ' pluginDataPath will contain a USER Profile (my documents) folder path
                              ' suitable for storing WRITEABLE settings to
                              ' this would make your plugin OS compliant (VISTA and onward)
                              ' not to mention, its proper programming, user data should NOT be stored in "Program Files"
                              ' example (typical vista): "C:\Users\Username\Documents\RideRunner\Plugins\MyPlugin\"
                              ' App.path will be the path of the ACTUALL LOADED .dll (not recomend for any writes)
                              ' uncomment code below if u need the directory
                              'Dim t
                              't = GetAttr(pluginDataPath)  ' if error, then we dont have this directory existing
                              'If IsEmpty(t) = True Then CreateFolder pluginDataPath
                          End Sub
                          and i obtain a syntax error
                            Code:
                            RRSDK.SetUserVar "myvar", 100
