Venice7 (Master) Radio Module and skinning
  • Venice7 (Master) Radio Module and skinning
    Hi
    Anyone using a Venice7 (Master) Radio Module and care to share there skin file with me?
    I'd like to see how to make a new skin with the commands available to this tuner.
    I'm perticularly interested in the FM support commands.
    The road is long but we are getting there.
    i thought carwing lite , ( comes within rr Installer ) hs a test skin i did in it
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      I have seen that one but did no know if the skin was a general radio skin or specific for the venice module.
        specific to v7 module just keep the skin name ,
          Ok thanks.
          Have you actually worked with this module. What is you opinion about it ?
            i have not actually worked with it , i know users that have , its ok as for as i can tell ,i use v5 module as one of the early 1's much better for a plugin access, looks better skinned to ,
            but i really can't comment on how v7 is
              Which user do you know that use it. Are they member of mp3car ? Maybe I can ask them.
                i know mitch linked himself to ,for testing , and i think boelle had 1 but blew it up lol....
                but you may get some response later , but i would check the dab thread in main mp3 forum
                  From what I see in the skin file, all of the commands are for the DAB section.
                  Are the same commands used for the FM section ?
                    pretty much . its how mitch did it so we could with a bit of playing make a univrsal skin
                      look at the venice7m_radio.skin and read the venice 7m documentation in the documentation\radio modules folder
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Sun, Come shine my way
                      Wind, Carry me home
                      The piece of me that died
                      Will return To live again
                        I took a look at those files but most all commands mentioned look that they are for the DAB section. Are the same commands also for the FM section or is the FM section degraded ?
                          its all the SAME
                          what commands can you possibly be looking for
                          they are all there
                          BAND, TUNEUP...blabla...
                          you can and should use DABDOWN, DABUP in fm...
                          try carwings in fm, you will see
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            I've done a V7 (master) skin for Simplistique if you want to have a look at that. It's very simple though and, as Mitch says, the button commands are shared between FM and DAB.
                              Yes please, where can I download it from ?
