cant remove songs from database?
  • cant remove songs from database?
    Hi I am running the latest ride runner with dfx 5.03 and have 19752 songs. If I remove 10 songs and rescind db the scan results show 19742 dogs so it looks like they are removed except it doesn't report any songs have been removed from the db??? When I go to ny entire collection after the scan it shows 19752 songs again. If I go to play one of the removed songs it just sits there doing nothing. I am using Winamp as the player.
    I would say turn on the RRMedia debug options. With RR running, right click the RRmedia icon in the system tray and Open storepath locaton, then open up the RRMediadb.ini file.
    Set both of the debug options to true under the [General] section, save, close. Then close and restart RR.
    Go thru same process as you posted above then Attach a zip of all the xx_debug.txt files found also in the same folder that the ini file was.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      many thanks please find files attached.....cheers
        Two things, first gonna need you to redo this w/ some updated files. You should have had a builder debug log as well but i don't see one. I will attach more up to date files for you to use and then repost the debug files again using the new files.
        DFX 5.1.1 Skin
        Appstore Link
        RRMedia
        RRExtended
        DFXVoice
          Is the file u want me to download below your Sig? The rrmedia?
            No, I posted in another thread a newer RRMediaDb.exe but i want to make sure that you also are using the newset builder too..
            Use these files. You should be getting three debug files:
            RRMedia(Ext PI)_debug.txt
            RRMedia(Main)_debug.txt
            RRMedia(Builder)_debug.txt
            If by chance you have the older RRMeda files (v1.2.2), you should get rid of them.
            Unregister the following files:
            RRMediadb.dll - RR's root (C:\Program Files\RideRunner)
            SQLite3.dll - C:\Program Files\RideRunner\RMDatabase\Support Files
            Cddbcontrol.dll - C:\Program Files\RideRunner\RMDatabase\Support Files
            Then delete the whole RMDatabase folder.
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              Hi blue.....this is turning unit a bit of a nightmare...
              Rrmediadb.dll is in plugins/rrmedia
              Sqlite3.dll is in skins/dfx5/browser/xulrunner
              Cddbcontrol.dll is in plugins/rrmedia/support files
              And I don't have a folder called rmdatabase to delete anywhere on my hard disk....
              I am on xp if it helps and do I just do what u said with these files in the locations I have?
              Thanks...
                Update...
                I completely removed dfx and left over files...fresh install and did another full db scan and it still says I have the 19752 songs even though I really have about 100 less than that as I have deleted them. The files you sent are exactly the same as what I have installed.....
                  Well, the only one different really should be the RRMediadb.exe as I have added better debugging info for tracking issues. To make sure that a complete fresh scan, would be to delete the RRMedadb.db file in your root musicpath, as that is where the database is located at. I could see being maybe a few file count different, but certainly not a 100 different. If everything is working fine execpt the odd count, then I wouldn't worry about it too much. Not worth the time to investigate otherwise....
                  DFX 5.1.1 Skin
                  Appstore Link
                  RRMedia
                  RRExtended
                  DFXVoice
                    Hi Blue,
                    I have to honestly say that this is really so important to me that it is a dealbreaker! I have around 20,000 songs & an awful lot of them are compilation albums. I have in the past with CF been using the delete button as I go along to reduce my "Car Music Collection" The problem I have is that until you release the delete song in your next update I am deleting the songs manually outside of RR & am unable to get the RR Database to match the actual songs on the hard disk & when as song that I have deleted comes to play on RR, it just sits there until I select the next song.... I really really do not want to appear to be making demands or ungrateful its just that the media side of the front end is critical to me & the reason I swapped from CF in the first place. Is it possible that you could give a guideline as to when the delete song button will be included so I can make a decision please? just a rough pointer that's all....
                    Many Many Thanks for your time so far, I really do think that this is a great product & look forward to all the improvements in the future.....
                      Did you delete RRMediadb.db and rescan like Blue said. This file will likely be in the same folder as your music files. It will not be in the RRMedia folder. If you do that there is no way that the songs you have deleted can show back up in the database.
                      Also, are you sure that you're not confusing the database with playlists? If you have a song in a playlist and delete the song from your computer the playlist will still have the song in it unless you also delete it from the playlist or recreate the playlist. That's just the nature of playlists and has nothing to do with RR/DFX or RRMedia. Playlists and the RRMedia database are totally unrelated.
                        Hi,
                        If I delete RRMediadb.db & rescan then yes the media database is all correct, but that will completely write off the uses of the program that I am really keen to use like, how many times a song as been played, when it was last played & most importantly play new songs added within a time scale, I wouldnt have thought that deleting the db file & rebuilding every time I add/remove songs would be the correct way to go....maybe if I explain what I am trying to achieve then someone can help me if I am doing something wrong?
                        1, I want to add my entire mp3 collection (around 20-21,000) songs
                        2, I want to delete songs (from the hard disk) as I go (PLEASE bring that delete song button asap)
                        3, I want to keep the ratings of each song as I go
                        4, I want to be able to add/remove songs and keep that information in the database so I can use the last time a song was played, when it was added etc....
                        Any help would be VERY appreciated ;-)
                        Cheers
                          Bumpity Bump
                            No, your not doing anything wrong, you are just having some hiccups in the process. I have found a few things while working in the v2 of RRMedia that could be causing what your having issues with. You will not loose the ratings if/when you have to delete the db, as the plugin keeps a separate backup of those for such occasions, just don't delete the Rate.in_ file, and when you do a rescan it will readd the ratings to the songs.
                            DFX 5.1.1 Skin
                            Appstore Link
                            RRMedia
                            RRExtended
                            DFXVoice
