roadrunner api
  • roadrunner api
    My buddy is helping me write A pluging for ride runner to control my uniden bcd996 police scanner. He is looking for some kind of api to go off of thanks mike
    RideRunner SDK Examples
    When you install RR, make sure you let it install the extension examples, (it will ask when installing). Then look in:
    C:\Program Files\RideRunner\RRExtension Plugin Examples\
    There are examples in VB6, .net and C#.
    If you are working with AutoIt, you can access RR's SDK like this example script:
    PHP Code:
    $rr
    ObjCreate("RoadRunner.sdk")
    $rr.Execute("Audio")
    $TrackNumber=$rr.getinfo("=$TRACKNUMBER$"
    The first line opens communication with RR. (Only needs done once at the top of your script)
    The second line tells RR to go to the Audio screen
    The third line gets the current track number and saves it in a variable
    In the 2nd line, any commands that RR understands can be done. Such as "SetVar;MyVar;My Test Text" Sets the variable $MyVar$ in RR with "My Test Text"
    Have a look in the RideRunner\Documentation\SkinCommands.txt for an extensive list of commands, labels, setting variables ect.
    Lastly, fire up the SkinTool in the RR directory. It is a nice GUI that will let you send commands to RR, and get information from RR, and is a, indispensable testing tool.
    My Fiero Build Thread
      John
      Thanks so much. But we have complied the myextesion demo and it wont show in rr. We left it as defaults. Any help would be apperciated.
        If I remember correctly chuck's skin had a scanner plugin, wonder whatever happened to him?
        TruckPC - gutted, being used for test setup
        BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
        BlazerPC - Nexus 7 with Timur's USBROM
          Originally posted by themlruts View Post
          John
          assuming you put the .dll in the plugins directory
          and regasmed it
          thats enough info to have you solve it
          -Thanks
          Mitch
          www.rush2112.net
          Sun, Come shine my way
          Wind, Carry me home
          The piece of me that died
          Will return To live again
            John
            Compiled in .net or VB6? I have not made the switch to .net yet, so not sure how much help I can be there.
            As Mitch mentioned, make sure the .dll is in the plugins dir, and it is registered.
            When you say it "won't show in rr", I am not sure what you mean. You have to fire one of the test commands to get it to do something. If you mean it is not showing in the plugin manager, then it is definitely in the wrong folder and/or not registered.
            Till you can get things moved to the plugin, you can do some testing with the exec.exe in the RR folder. Simply run that exe with command line options to pass the info to rr.
            For Instance:
            Exec.exe Audio
            That line in a .bat file will send the "Audio" command to RR. It is good for testing, but far better to get the code into a plugin than to run an .exe for every single command, and the fact that it is one-way communication as well.
            You can IM me on Yahoo at johnwpbfl
              Thanks for you help. We decided to make a standalone exacutable at this time. I would really love to get a direct plugin for this scanner.
