resolutions / settings
  • resolutions / settings
    Currently running a 7 inch touchscreen monitor with resolution 800x480. I noticed that the config tool does not list any 800x480 resolutions so I figure that it's not supported? If I use the default or next resolution up (800x600), the bottom of RR is cutoff. If I use the previous resolution (640,480), RR won't fill to the bottom of the screen. Since it's not listed in the resolution, I guess there is no way around (even tried editing the .ini for 800x480). Is this correct? and what might the best settings be so it doesn't look half bad?
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
    800 x 480 is supported, really any resolution is support
    if you set your pc resolution to 800x480...
    you will just need a skin that is in that aspect
    you can scale any skin..might not look great..but you can do it...
    there are prob a bunch of skins for that resolutions
    you would edit the general.ini file of the skin
    ie:
    for carwings
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=480
    carwings actually looks ok in this squezed aspect
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Well, that works out well. Didn't know the skin had it's own resolution settings aside from the program. Thought the skins just scaled to whatever the program resolution was set to. But thanks for the help!
        actually the program doesnt have any resolution settings
        at least far as i know
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
