Passing an ibusRR variable from RR into a flash gauge.
  • Passing an ibusRR variable from RR into a flash gauge.
    One last question from me, I promise!
    I have no problem passing internal variables or variables from fusionbrain in to flash animations, however I cannot pass a variable from ibusRR into a flash animation.
    Passing value analog0 from Fusion Brain works well:-
    L01,12,10,0,0,0,0,0,0,"arial","analog0",""
    Passing value gpsspd from internal GPS works well :-
    L01,16,10,0,0,0,0,0,0,"arial","gpsspd",""
    Passing value $COOLANTTEMP$ from ibusRR variable doesn't work:-
    L01,16,10,0,0,0,0,0,0,"arial","$COOLANTTEMP$",""
    Using this command displays the variable on the skin OK so I know that the variable is being set:-
    L07,493,537,97,14,255,120,000,12,"arial","=$COOLAN TTEMP$","LEFT"
    I am using the variable _root.COOLANTTEMP in my animation. Is this correct?
    Where am I going wrong?
    My Projects:-
    2010 BMW X1 install
    1955 Austin A30 install
    Solved
    I think I have now solved the problem,
    I have added an fscommand to my flash gauge to set the variable using SETFLASHVAR.
    fscommand("SETFLASHVAR;RANGE;$RANGE$");
    spdtmp = _root.RANGE;
    Thanks to a post from 2007 that helped me with this one!
    My Projects:-
    2010 BMW X1 install
