RR 12-12-2010 Release
  • RR 12-12-2010 Release
    HOT Fix Release, this fixes the slider painting issue
    Download Here
    Thanks to Forum members for finding this bug!
    The solution was to fix the incorrect documentation on the slider
    parameters
    History:
    Code:
    12/13/2010
    # Slider skin definition documentation - See Skin Commands.txt
    + Safety code is added to make sure the slider images are in the h,w bounds of slider area
    # Fixed WMP player not restoring last player volume correctly
    12/12/2010
    + Support for tunes 10 as player
    # Fixed possible players not pausing on resume, if paused when exiting
    + Setting; "resumemusic=3", new mode to override pause, music will always resume playing
    + Additional debug log entries when player is initialized
    12/08/2010
    # URLs inside of m3u/m3u8 now work correctly
    12/08/2010
    * Skincommand; Events can now have *ON as 1st 3 characters when generated in a plugin, and the
      plugin coder wants the event to be public, IE seen by other plugins directly
      ex.  "*ONMYCOOLPLUGIN_HOTSPOTDETECTED" - (this will pass into all plugins, EVEN if translated in exectbl)
      ex.  "ONMYCOOLPLUGIN_HOTSPOTDETECTED"  - (this will not pass, to other plugins)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks! - Downloading..
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      Installed and now all the sliders are fine
      Thank you!
        http and mms streams inside m3u playlists now work well,
        Thanks.
        My Projects:-
        2010 BMW X1 install
        1955 Austin A30 install
          I had a slider that ran very well with the old RR versio but now it is very little:
          This is my code:
          Code:
           S,736,97,47,339,545,75,35,30,v,"SliderBackGround.gif","SlopeSliderImages\cursor.png",5,"$GPXSLIDER1$",
            dont know, but there is a slider image issue... but it looks to be a OLD OLD OLD issue
            my ftp has a newer RR
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              not to mention... that example slider you posted is so out of any usesable context
              ie.. whats GPXSLIDER1 at the time
              if its say 0, its gonna be tiny
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                also... where are u coming up with the x1,y1,w1,h1?
                S,736,97,47,339, 545,75,35,30
                why so radically differnt? do we not understand what it is for (i didnt a few days ago)
                and i have no idea what skintool is doing
                try:
                S,736,97,47,339, 736,97,47,339.....
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  GPXSLIDER1 is a variable that i have added to Gpsexec
                    yea, so... when you say its very little, i have no idea what that means
                    a slider is little when its closer to 0 than 65535
                    just make sure you're running RR 12/12/2010
                    and re-eval your slider x1,y1,w1,h1.... id make em the same as x,y,w,h
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Ok , i see the error,
                      Before , i had that, with this code:
                      Code:
                      but now with the same code with RR 12/12/2010, i obtain that:
                      I understand that the issue is with the slider that has changed.
                      So , i have replaced my first line by:
                      Code:
                      S,736,97,47,339,736,97,47,339,v,"SliderBackGround.gif","SlopeSliderImages\cursor.png",5,"$GPXSLIDER1$",
                        pierrotm, so all good now?
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          Absolutely mitchjs,
                          Big thanks
