*** New Product *** MJS Gadgets USB-IO-1
  • *** New Product *** MJS Gadgets USB-IO-1
    I got a new Product, available in days, from right here at mp3Car.com
    (Why announce here, cause I designed it for primarily Ride Runner, and I love you guys )
    its a USB I/O interface
    Its not meant to compete with any existing one out there, just be simpler
    Its in the same size ENCLOSURE as my UAS4 (USB Audio Selector)
    (so approx 3" x 2" x 1")
    the Key is the Ride Runner Plugin i did, hopefully i thought of everything
    (which of course i didn't, but it can expand it as requested)
    the manual is attached
    Features:
    • USB Powered and Controlled.
    • USB HID Device – No drivers needed.
    • 4 – Relays (1 amp) selectable Normally-Open or Normally-Closed
    • 4 – Digital Inputs (5 – 30 volt opto-coupled).
    • Plug-able Terminal Blocks, (Phoenix style).
    • Road Runner plug-in available.
    • Centrafuse plug-in available.
    • Developer .DLL available. (.NET Based)
    • Includes 6’ USB A to Mini-B Cable.
    Some things you can do with it:
    • Control Power Antenna
    • Control Audio Amplifiers
    • Control Power Window Module
    • Control Accessories
    • Control Incoming Phone Call Notifier (Led in cluster)
    • Detect Parking lights on
    • Detect Parking Break (to allow video)
    • Detect Car in Park (to allow video)
    Almost unlimitied ideas...
    (yes you can use more than 1)
    Suggested Retail $55
    Some Pictures:
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Ride Runner - Plug-in Documentation
    (yuck #code formatting, looks bad, readme.txt is attached)
    Code:
    RideRunner Extension Plugin for MJS Gadgets USB-IO-1
    !REQUIRES .net 2.0 sp2 framework
    u = Unit number 1 - n
    r = Relay number 1 - 4
    s = State 1, true, 0, or false
    is = Input State "ON" or "OFF"
    serial = MJS Gadgets USB-I/O-1 Serial Number String
    var	= RideRunner user variable
    ** SKIN COMMANDS
    "MJSGIO_ALLOFF;u"								- all relays off.
    	ex. MJSGIO_ALLOFF;1						- turn unit #1's relays off.
    "MJSGIO_SETRELAY;u;r;s"					- Set a relay on or off.
    	ex. MJSGIO_SETRELAY;1;2;1			- sets unit #1's relay #2 on.
    	    MJSGIO_SETRELAY;1;1;0			- sets unit #1's relay #1 off.
    	    MJSGIO_SETRELAY;1;3;true	- sets unit #1's relay #3 on.
    "MJSGIO_EVENTS;u;s"							- Enable/Disable events for unit.
    	ex. MJSGIO_EVENTS;1;true			- Enables unit #1's events.
    	    MJSGIO_EVENTS;1;1					- Enables unit #1's events.
    	    MJSGIO_EVENTS;1;0					- Disables unit #1,s events.
    "MJSGIO_GETUNITID;serial;var"								- Searches system for device with serial number
    																							and assigns user variable with unit number.
    	ex. MJSGIO_GETUNITID;21436587-1450-011F080C7-02AF8598B518;iodevice
    																						- will set iodevice with unit number if found
    																						- Events, "ONMJSGIO_GETUNITID.SUCCESS" &
    																							"ONMJSGIO_GETUNITID.NOTFOUND"
    ** EVENTS
    "ONMJSGIO_START"														- Fired when Plugin is running, after ONSKINSTART
    "ONMJSGIO_GETUNITID.SUCCESS"								- Fired if "MJSGIO_GETUNITID" is successfull.
    "ONMJSGIO_GETUNITID.NOTFOUND"								- Fired if "MJSGIO_GETUNITID" is unsuccessfull.
    "ONMJSGIO_INPUT.u.i.is"											- Fired when MJSGIO_EVENTS are enabled for this unit (u)
    																						- i = Input number 1-4
    																						- is = Input state "ON" or "OFF"
    	ex. ONMJSGIO_INPUT.1.1.ON									- Unit #1's Input #1 is ON
    	ExecTBL.ini ex.
    		"ONMJSGIO_INPUT.1.1.ON","PlaySound;$RRPATH$Plugins\RRMJSGUSBIO\Example\boing_x.wav"
    ** SKIN LABELS
    ** SKIN INDICATORS
    "MJSGIO_RELAY;u;r"													- Indicates current state of relay (true = on, false = off)
    	ex. MJSGIO_RELAY;1;1											- Indicates current state of unit #1's relay #1.
    "MJSGIO_INPUT;u;i"													- Indicates current state of input (true = on, false = off)
    	ex. MJSGIO_INPUT;1;1											- Indicates current state of unit #1's input #1.
    ** USAGE NOTES
    ** THANKS
    ** HISTORY
    v1.0.0 Initial Release
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
      I think one key thing to add to your list, is the ability to use it to control voice recognition. You could hook a momentary switch to it, and have it trigger RR to listen for commands when using the voice recognition plugin by jebus.
      My Fiero Build Thread
        Thanks, that's very cool. The voice control thing is a good idea, although I personally have it solved already.
        Could it be used to control like RGB leds, like blue for speed trap, red for incoming calls, green for incoming phone calls, bright white when doors open, etc.? (say you have a led strip in your instrument cluster, wherever - but which can change colors according to I don't know what controls those rgb things, resistance, pulses?).
        On second thought, I think the above would work best if it could work w/o the computer being on though...
        Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
        Skin: MetroSex on the Beach preview
        07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
          As it is right now, you could hook a couple of different color LED strips to different relays. Turn on the one you want for the color you want ect. Talking to Mitch, me mentioned you could also have say a red and a blue hooked to different relays, and turning on both would give off purple light.
          Of course that is just a temporary solution.... Until.... say..... ummmm.... another "Gadget" comes along?
          I'm just saying.....
            Cool interface !
              oh you know too huh lol cant wait!
              Live mp3Car Facebook Chat
                Awesome gadget! Ill be purchasing one. I have been waiting for a simple USB controlled relay bank for some time now. The real purpose is to control external circuits from touchscreen buttons. (Example, ground trigger your headlight switch from RR, or positive trigger your amplifier from RR, or lock unlock your doors from RR)
                It can be used to control even higher draw circuits if external relays are added.
                I suppose you could use it to light up some LED's or integrate it into voice control contraption, but IMO these ideas are really missing the point of the device. This is my opinion though and everyone will have a different use.
                  For S & G's I may have to add a "start / stop" button to RR to fire up and shut down my engine
                    Got to find a way to use it in my up coming Sienna.
                    Too many good stuffs, no time to play with.
                    Still have the HD radio cable in the package unopen from 2-3 years ago.
                    Y2K Accord Dell GX150
                    EmoRebellion is a SCAMMER
                      same here, i have a hd radio cable now for almost 2 years. i simply dont have time to install the stuff. it sucks, but ill get time in a few months i think...
                      how does this io module different from a fusion brain? it seems like a simpler solution anyway
                        I think that for simplier tasks that you are talking about, this might be better/easier for solution for them.
                        Next in line: RRMedia v2.0
                        DFX 5.1.1 Skin
                        Appstore Link
                        My RideRunner Plugins
                        RRMedia
                        RRExtended
                        DFXVoice
                          It differs in the fact that the relays are built into this device. Just hook up the wires to something you want switched, and it is under software control. Also the fact that no drivers and special software are needed to configure it.
                            and it directly controlled via RideRunner (plugin) commands
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              Somebody do an example skin right quick so i can visualize..
                              OLD SYSTEM (DEAD)
                              Intel D945GCLF2 Dual Core ATOM
                              Lilliput 7" 629GL 2008 LED Backlight
                              BU-353 USB GPS Receiver / iGuidance / IGO8
                              M2-ATX Power Supply
                              RideRunner Front End / Various Skins
                              Windows XP SP3
