Can't get RDS texxt with Venice5 radio module
  • Can't get RDS texxt with Venice5 radio module
    Has anyone got RDS text to work with the Venice 5 radio module and the default RR skin?
    The radio modules works great but I cannot get RDS text to be displayed, I have verified that RDS text is broadcast using my home stereo.
    Any ideas ?
    The road is long but we are getting there.
    it could be the skin. I have had no issues with the freedom skin.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
      Where can I get the freedom skin to have a look at the radio section ?
        http://www.nrgizerbunny.com/DABRadio.html
        go to the very bottom of the page under downloads..
        Visit my Homepage
          Thanks, Ill try and see whats wrong.
          So this will work with the venice5 and receive RDS on FM frequencies ?
            Yep, if you have a look at the videos on the link I have posted, you can see the venice running FM (with rds text) and DAB.
            Just make a note, a "DAB" car antenna has split outputs so it will not pick up FM and DAB together unless you build a multiplexer.
            Visit my Homepage
              rr label cmd "RDSText"
              in dab mode works fine, but in FM mode can take some time for it to appear and not all stations transmit rdstext in fm mode..
              i would use skintool and stick rdstext in the label box and tick auto update , switch between the 2 modes see what you get
              Riderunner / Genesis
              Wifiman_NET:Version 1.0.0
                Just tried the freedom skin but RDS is not working in FM. The station is broadcasting RDS but it is not showing. We do not have DAB here in Greece.
                  i think i remeber now , mitch could not get much in fm mode to work nicley ,,, only DAB
                  and i think RDS text was 1 of the issues , to which case you won't get rds text in fm mode...
                  come to think of it , i hav'nt seen rds in fm mode , on the very short times i have used it ....
                    OK, that explains it then.
                    So it's up to Mitch now.
                    Thanks for the info
                      i don't think mitch can do any more , its down to the info the chip can offer him , to use ,
                      without a true sdk , which niether v5 v7 offer
                        just so i don't confuse myself.
                        Are we talking about RDS as in radio station name
                        OR
                        RDS as in RADIOTEXT?
                        The venice 5 cannot do radiotext. It can only do RDS
                        Visit my Homepage
                          V5 does support radio text. The function may have got lost during the rewrite of the SW.
                          Here is V5 receiving classic FM at 100.6Mhz showing station name as well as the text.
                            Test apps for V7/Verona on slave
                              RDS text is working just fine from both Venice5 (master) and Venice7 (slave) modules so it must be an error in the software, not the modules.
                              Failure is not an option...
                              __________________________________________________ ______________________________
                              The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
